The unit blinks 11times
Sounds like sensor beams are out of alignment or obstructed. make sure nothing is blocking the line between the two beams then check whether anything is on the lenses or if one is visibly out of alignment. if one is out of alignment, with your hand held remote in hand make small adjustments (up or down ) and test after each adjustment until it closes. when it does close, tighten the nut that holds it in position.
