My nokia 3310 ask for security code and I don't know what is the security code for this. imei number 350144300943414 and tried the master code unlock 3333410247 but still didnt work.
Hi visit Unlock-free.com here they ask you the mobile model and the IMEI number of your mobile .Then at last they generate code to reset your mobile at free of cost.
You can unlock your Nokia 3310 at wickedunlock.com using Master reset codes!! Specify your phone's manufacture, model and IMEI number to get the codes. At wickedunlock the codes are affordable and also the unlocking process is simple!!!
*(asterisk) #(number sign) 0(zero) 6(six) #(number sign) The CODES:
*#06# - displays the unique serial number or IMEI number
*#0000# - shows the firmware or software version details
*#2820# - Bluetooth (BT) device address
press and hold the ZERO (0) button - brings you to the homepage of your wap/gprs
press and hold the MENU button - launch the phone's task manager. you can then switch between active programs or terminate a running application by press the CANCEL/DELETE (c) button.
*#7780# - restores user defined settings to factory default settings. programs, calendars, and contacts are unchanged. you will be ask to input your security or lock code to proceed with the restoration.
*#7370# - reprograms your phone memory to factory default. all files will be deleted. you will be ask to input your security or lock code to proceed with the phone memory format. backup your messages, contacts, and other important data before proceeding. NOTE: this is equivalent to hard format for Nokia Series 60 1st edition phones (N7650, N3650/60, N-Gage/QD). If you are using Nokia Series 60 2nd and 3rd edition phone (N6600 and above), this code will not fully format your phone memory, you need to do the hard format (3-keys combo code) instead.
turn ON your phone while holding together the green (call) button, *, 3 - reprograms your phone memory to factory default. all files will be deleted. you will be ask to input your security or lock code to proceed with the phone memory format. backup your messages, contacts, and other important data before proceeding. NOTE: applicable only to Nokia Series 60 2nd edition and above phones (N6600 and up).
*#7370925538# - reprograms your phone's wallet application. all information on your wallet will be erased and the wallet code will be removed.
From the below link u can getthesecurity code by providing your IMEI number,to get the IMEI numberumust just*#06# or at back side of the mobile u will have serialnumberis as same as IMEI Number,
hi pittadd; the default security code of nokia phones is 12345, if it will not work.try this code here...0203416706 ( this code is for your imei only)
i haven't tried doing it because i don't have a nokia phone, you should be able to set your security code again right after you enter the 10 digit numbers. i wont guarantee 100% working, hope it helps
Default security code is 12345 Unlock Code - is 5126700231 only if you have given correct IMEI no of your mobile and mobile model no ---------------------------------------------------------------------------------------------- Low feed backs hurt my ratings and I tried my level best to resolve the issue. so show your appreciation by rating it. Thanks for using fixya support..You have a wonderful day
I haven't change and done anything on security code AND TRIED 12345 but still didn't work. I dont have such nokia cable. tnx
i forget my security code my phone
