>Check your phone, that is it on.
>Hold and press Green handset + Red handset + Camera key.
>Release holded keys, when you see Nokia logo.
>Now tap your lock code. (The default lock code is 12345).
>After this operations your phone will reset and maybe restart.
OR
>Press Power button, until your phone turns on.
>After that press Menu button and goto Settings -> Phone -> >Phone management -> Factory Settings -> Delete data and restore.
>Confirm your decision -> press Yes.
>Done
My Samsung GT-E2120i phone won't work. When you turn it on all it does is display GT-E2120 SAMSUNG and then it just blinks - display/black screen/display/black screen etc. Then it won't turn off - the only way to stop it is to remove the battery.what do I do to solve this?
When it's green that just means that you're phone has service. When it blinks red that means you have a text message, virgin alert, missed call, or sometimes a voicemail message. You can turn of the status indicator light by going to Menu > Settings > Display > Status Light and select "Off".
My Samsung gt-e2120 phone won't work. When you turn it on all it does is display GT-E2120 SAMSUNG and then it just blinks - display/black screen/display/black screen etc. Then it won't turn off - the only way to stop it is to remove the battery
here i hope this helps you Display Settings Changing the Text Greeting The text greeting can be up to 15 characters and is displayed on your phone’s screen in standby mode. You may choose to keep the phone’s default greeting (“Sprint”), or you may enter your own custom greeting. To display or change your greeting: 1. Select > Settings > Display > Greeting > Custom. 2. Enter a custom greeting using your keypad and press . (See “Entering Text”on page 39.) (To erase the existing greeting one character at a time, press . To erase the entire greeting, press and hold .) Changing the BacklightTime Length The backlight setting lets you select how long the display screen and keypad remain backlit after any keypress is made. To change the Main LCD or Sub LCD backlight setting: 1. Select > Settings > Display > Backlight. 2. Select Main LCDor Sub LCD. 3. Select Always On, Dim Only, or a preset length of time. To change the Keypad backlight setting: 1. Select >Settings>Display>Backlight>Key. 2. Select Always Off or a preset length of time. Note: Long backlight settings affect the battery’s talk and standby times. Note: The Always On setting returns to the previous value the next time you turn on the phone. Your Phone’s
If you have vmail and no msgs and the only light that is flashing is the light at the top right of the display, what that is flashing for is someone set a msg to your phone from another phone on your system. Try this :
without picking up the handset , dial 43 .
the display should show the ext # that set the msg and an option to reply or clear . press the btn under the display where it says clear and the msg will clear and the light will go out.
Hi Dan, Yes it is a very nice system, but like any device it is sensitive to electrical storms and power fluctuations. A surge or sag (AC power going up or down), can cause the sensitive digital chips to get damaged, and from my experience if you have tried resetting the unit, and your msg lites continue to flicker and the LCD is blank, it has some serious damage and needs repair or replacement.
