Buck Dodge Ram 1500 2002 Car Radio/stereo Wire Harness Plug Logo
Posted on Mar 25, 2009
Dodge 1500 service engine soon
2002 Dodge 1500 - A/C stopped blowing cold air and then the service engine soon light came on. Truck is running fine - no loss of power or fuel economy
  • Anonymous May 11, 2010
    Just a guess
    Check the A/C drive belt.
    Aduz
Anonymous
Level 1:
New Friend:
  • Contributor 17 Answers
  • Posted on Jun 22, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
17
Questions
Helped
13407
Points
24
Need to get A/C levels checked and might need more freon and go to the auto parts store and have them run an OBD2 scan on your truck. Than go to www.canobd2.com and put your vehicle and code in and see what that code is in reference to.
Ford F150 only blows heat when truck is driving
May a a vacuum or electrical problem that actuates the blend door.
98 dodge ram 1500 5.2 the truck will start but it will not idle.
I have a 2000 Dodge Ram 1500 that will blow cold and hot air for only a few minutes. After that is only ambient air temps. It is a 5.7 ltr, automatic with only one set of climate controls. The heater core...
you say it will blow cold and hot air for only a few minutes. You don't say but I assume you mean will blow cold a few min. when turned on AC max , blow hot only a few min. when turned to heater hot. Assuming thats the situation and you say AC charged and shows good on the low side -you should charge the AC to a full charge on the low side will cause problems with the AC air compressor kicking on and off. I suggest while the engine is running and turned to AC cold max watch the AC air compressor clutch to see if it does indeed kick on and off if so charge completely. As far as the heater make certain you coolant is all the way to the top and the best way to do this is when engine is completely cold remove radiator cap and fill completely and completely close cap then fill overflow container just to the cold level. That should fix your problem.
8helpful
3answers
2002 Dodge Ram 1500 - The heater blows cold air when it sits at idle but blows warm air when it is being driven down the road. A/C does the opposite, doesn't blow cold air when diling, but I figured this...
the heater blowing cold at an Idle and warm while driving it,is usually low coolant in the radiator,remove the radiator cap when engine is cold,fill to the top,and fill overflow tank to full,if that doesn't take care of it,check the heater hoses at an idle and see if they are both the same temp,it might be a water pump not doing its job.
2006 RAM 1500- COLD STARTING POPPING FROM INTAKE, AFTER WARM OK
sounds like u might have a sticking valve. i do know that they have had alot of valve problems with this motor
Rpm's jump temporarily when driving like trans. slipped,
CHECK THE CODITION OF YOUR IAC SENSOR(IDLE AIR CONTROL) IT MAY NEED SERVICING ALSO THE COLD AIR INTAKE MAY NOT BE COMPATABLE WITH YOUR ENGINE I'V SEEN SIMILER PROBLEMS WITH TOYOTA CAROLARS WITH THE SAME SYSTEM TRY REPLACING THE OLD INTAKE AND SEE IF IT MAKES A DIFERENCE
2answers
2002 Dodge Ram 1500 A/C Blows Hot When Stopped and Clicking Sound
if the compressor is turning on and and off R1-34 level is low recharge system.
3answers
With ac running cold, blows warm when truck is stopped
I have a dodge 2007 ram 1500...most likely its an RPM issue. The compressor requires a certain RPM to maintain the required pressurized vapor.
Top Buck Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
Are you a Buck Car Audio and Video Expert? Answer questions, earn points and help others
