I dont no how to do it i was woundering if i can get some help with like a diagram or something to help also i was woundering if i hooked up 2 dvc subs to my 1ohm amp is it possible to get the full power out of my amp or if not wat if i got 4 dvc subs and put them to the 1ohm amp would that work thank u for the help
I would look up "series" and "parallel" wiring on the net. Parallel will lower your ohms, which is good- especially for you since your amp is 1ohm. use 1 channel of your amp (unbridged...bridging an amp could increase output, but will Raise the ohms) connect the positive terminal with a wire that goes to the positive on your first sub, and from there, connect a wire from that same positive terminal to the positive terminal on your second sub. do the same thing with the neg. wire. This is called parallel wiring.
