Why when I plug in the AC power on won't stay on On battery stay for a while and when I run the program ubuntu 13.04 64 bit it become colored blank I know its not the memory I want to know whether its motherboard or the processor so I can eliminate the unnecessary cost.
SOURCE: Toshiba satellite M55-S3293 power adapter
Welcome to Fixya
Most likely the problem here is the battery. Although its telling you that its 100% charge, it doesn't mean that the battery is in good working condition. Try first reconnecting the battery. Maybe it's not making good contact with the motherboard. Ifsame problem the you might need to replace the battery first. If replacing the battery would not help then the problem is the motherboard itself.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
SOURCE: My Toshiba Satellite A505-6989 hangs
Hi laxboy001460,
This is a No Boot issue but just to isolate the issue for us to determine if it's a software or hardware issue kindly proceed with the steps below:
Hope this helps.
Thank you for using FixYa.
SOURCE: Why My TOSHIBA SATELLITE A660-13Q Froze during
Possible that PC is hanging up as there is fault on the OS ( operating system) . So open the internet options in the browser and clean all the cookies, temporary internet files, defragment the drives and RESTORE the PC to an earlier set date. You can use a registry cleaner like Advanced system care. Download from the site and check you system for corrupt files. Also use a good antivirus software which is active to keep your system performing without an attack on the OS. Remove all unnecessary programs installed which you do not use all the time and clean up the drives. This will free up the space and make your system faster. Also a fault on the memory can be another issue but an hardware problem that needs a probe.
If there is no response but the PC tends to work slower and occasionally hanging when a program is being executed then you might have to install the OS once again. Install the OS and then an antivirus before the drivers of the PC is installed.
SOURCE: Toshiba satellite L305-s5955 will not power up
If there is no power light and it can't charge your laptop, it is likely that the charger is dead. You need a new laptop charger. So try a new adapter to confirm the real issue.
There are two kinds of ac adapters for your toshiba l305-s5955
Toshiba Satellite L305 AC Adapter 75Watt 19V 3.95A
Toshiba Satellite L305 AC Adapter 90Watt 19V 4.74A
You should choose the right charger depending on your original adapter's specification. If the original one need 90w, you won't buy 75w that will bring damage to your laptop. If it needs 75w you can use 90w too.
