Televison & Video Logo
Posted on Mar 16, 2009
I want to hack my dvd player for my nissan quest 2007
In my dvd player for my minivan nissan quest 3.5 SE Model 2007, i can´t play dvd´s region 4, only plays region 1. How can I hack the dvd player? Thanks a lot
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 29, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
646
Points
Did you unlock the dvd player ? I am in the same boat ... Let me know if you have the detail.. Thanks
How do I get the MP3 player to work in a 2007 Nissan Quest?
you said CAN , i bet you meant CAN'T or CAN NOT. right?
the AUX port is just a line input, analog audio input,
it dont know MP3 .
it only amplies the analog audio found there.
you connect any device, to AUX. push play on the device.
then put car radio in to AUX input mode and play. the audio.
that is all there is to it.
the external device does all the heavy lifting, reading a file, and decoding it (mp3 decode) and then sends raw analog audio out.
the cable is sold and radioshack, or walfart or many other stores,
Target, most MP3 players, come with this cable,
they use mini phone plugs, stereo, type,. (3 contacts)
1helpful
2answers
How to make LG BP520 region free?
DVD REGION FREE & BLUE-RAY REGION FREE
To change the Region code on your DVD player, open Control Panel - System - Hardware - Device manager, and click on DVD/CD ROM drives, then right click on the DVD drive and click Properties then click on DVD Region.
You can enter a new region and it also shows you how many changes have been made.
NOTE you can make only 4 changes and the player will lock permanently on the 4th change.
If you want to play DVDs from any region you maybe able to upgrade the firmware to make it region free BUT if you make a mistake or installed the wrong firmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece of software (Passkey for DVD) that allows you to play DVDs from any region and Passkey for Blu-ray that allows you to play Blu-rays from any region. There are several available on the Internet but my favourite is DVD-Region Free From: -
www.dvdfab.com/products,free.htm
Was wondering what kind of rear and front brakes my 2007 nissan quest has
If it is the base model (S or SE) then it has disc front and drum rear brakes, if it is the SL then it has four wheel disc brakes.
1helpful
2answers
Samsung dvd-85k unlock code
Samsung DVD-V8500K
1. The player should be powered on, the tray closed without any disc inside, the logo "DVD Video Samsung" visble on screen and the message No Disc must have already appeared.
2. Press the "Subtitle" key on the remote - "No Disc" should disappear.
3. Using the remote control, key in the code
"5, 3, 8, 1, 4"
4. A number should appear - this is the player's region number that was last programmed.
5. Press the number of the region you require, or 9 for region-free.
6. Press the "Subtitle" key on the remote - region number should disappear.
7. Press Standby on the remote control.
NOTE:
Origin of this player is Region 5 so it`s a default setting
If code "5, 3, 8, 1, 4" doesnt work try this codes:
Region 1 - 2, 9, 3, 3, 4
Region 2 - 3, 8, 7, 6, 7
Region 3 - 5, 6, 7, 3, 2
Region 4 - 7, 6, 8, 8, 4
Region 5 - 5, 3, 8, 1, 4
Region 6 - 2, 4, 4, 6, 2
please rate me. its most helpful
2helpful
2answers
Is there a way to make my LG DVD multi regional?
please check this thread from answersbag.com
"1. Insert the DVD with Region Code which will not play. 2. Press 0000 on the remote and a new screen should appear showing Region Code for the LG V271 (as Region 4). 3. Select new region code as 0. 4. Press Pause to exit the screen and your LG V271 should now be region free."
3helpful
2answers
Samsung P480 dvd player- To Play all region dvds
how can I play *.mp4 files in samsung dvd player model no P480?
11answers
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
21helpful
Lg dv340 how to unlock regional codes for all codes
st1\:*{behavior:url(#default#ieooui) } Region Free Hack for LG DV340 DVD Player As I’m currently in South Africa visiting my family, I bought a DVD player as a prezzie for mom.
LG DV340 Region free hack for the model I bought at Game is below:
1, power on the player with no disk in the drive
2, pres pause on the remote
3, enter “314159′ on the remote
4, enter “0′ on the remote (0 = all regions, 1 = region 1 etc)
5, press pause on the remote
6, power the player off and then back.
Hopefully this helps someone else!
(Info from http://forums.dvd-swaps.co.uk/archive/index.php?t-2327.html)
Tags: dvd, lg dv340, region free hack
2answers
Multizone code
icon_minipost.gifRegion code hack posted by Tiger1, May 24 2007:
Hi I live in Australia and added this model.
acknowledging: Region code hack posted by ZoidsGodzilla, November 22 2006: for the Samsung DVD-V5600
1. Press the DVD button on your remote (the Samsung logo appears)
2. Press the SUBTITLE button on your remote
3. With your remote enter the code: 76884
4. The current region is displayed on the top left corner of the screen. (e.g. 4)
5. Press 9 on your remote (Region free)
6. Again press the SUBTITLE button on your remote
7. Enjoy the Region free player
If your player is NOT Region 4 by default then you will need to Substitute the Numbers in Step 3 with the ones Below.
Region codes:
RC 1: 2, 9, 3, 3, 4
RC 2: 3, 8, 7, 6, 7 (or 5, 7, 5, 3, 8 )
RC 3: 5, 6, 7, 3, 2
RC 4: 7, 6, 8, 8, 4
RC 5: 5, 3, 8, 1, 4
RC 6: 2, 4, 4, 6, 2
For Example if your Player was Purchased in the usa ( Which is Region 1) then Step 3 would read :-
3. With your remote enter the code: 129334
Have Fun :0)
16helpful
6answers
LG DVD player LG276
I picked up a LG DV276 DVD Player here in Australia but I am from the United States so I own region 1 DVDs. I unlocked my new player by instead 1. Open the tray. 2. Press 0 0 0 0 on the remote and a Menu will appear. 3. Press 0 for region free. 4. Press pause and power off.
I can play everything now, Aussie and US DVDs. Thanks LJ66.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
