Hi, my camera started to vibrate the image producing a noize. Sometimes I change from photo to video or change the zoom and the problem desapears for a time then back after some shots. The image apears shaking and the lens make a noize. I already changed the bateries but the problem back after some time. Could someone tell me the root cause and the solution for this problem ? I found some peaople who solved the problem lubrificating the stabilizer. Thanks.
SOURCE: SONY DSC H9 image shakes
CCD Failure!
known problem contact sony for free repairs dont worry just call them they will do it even if u are out of warranty
see this for sample advisoy and problem detail
http://esupport.sony.com/US/perl/news-item.pl?news_id=161&mdl=DSCT1
SOURCE: When I open the lens cover in the take picture
There is probably no user solution, it seems that optical lens vibration stabilizer is wrong/damaged, the only solution is to replace it.
SOURCE: Sony 18-70 kit lens vibrates badly
This is a lens problem, the AF motor of the lens is trying to engage the gears. Sometime it works, sometimes it does not... It happened to my sigma 70-300. The only solution is to have it repaired. If under warranty it should be free, if not.... might be cheaper to buy a new lens.
SOURCE: sony cybershot dsc-h7 -vibrating image, binding noise, blurry pic
if you alsow get vibrationOn Sony T100 and similar,
its the vibration canceling unit, i had the same problem.
if you have good hads you can fix it.( on your oun risk)
1) disasamble the camera, you will see black plastic box inside, this is he lens unit.
2) on the botom you see 2 scrwes, they are holding the CCD remove them and the ccd unit will come from the lens assembly
3) the next is the stabilizer unit it is the problematic one. it is located on the left side of the lens asebly and is held by 2 screws.
you can test it by puling out the cable connected to it (the conector is just under the lens) and verifign that the problem is solved. ( you can leave it this way it will shoot fine just without the anti shake)
4) to fix it take it out ,remove the plastic cover, you see the lens on a plastic mount it should be glued to the magnet under it. the problem is that the glue fals apart.
remove one of the pins on wich it slides, and take the lens and the magnet out.
5) reglue the magnet and reasemble the camera.
6) power up and test, for me that solved the problem
if you need more help you can mail me at adisarit(et)yahoo(dot)com this is spam mail so be prepared to wait a few days for reply.
