Most likely is your Internet connection.
Could you post more details?
Just from the description, your Internet connection to YouTube servers may be slow, which can be a) your actual Internet connection speed or b) YouTube servers, which COULD be bogged down by activity (slightly unlikely, but it could happen).
The problem will go away either on its own or if you get a faster Internet speed service. You are most definitely going to experience this if you are trying to access content using dial-up, but you may also experience this with higher speeds and trying to access HD content (which is much more data to receive).
SOURCE: video buffering
You need a faster internet connection.
If you are using wireless try connecting your laptop directly to your wireless router using a network cable, if the video's are not OK then you may have issues with your wireless. Could be interference or signal issues.
If it's still slow with the wired connection then you may just have a slow connection.
If you are on dial-up then forget about it.
It may help to ensure that you have an updated flash plug-in, visit http://www.adobe.com/products/flashplayer/ and upgrade if needed.
Video over the internet requires quite a bit of bandwidth so if your connection is slow or congested then it will have to buffer more. I don't beleive you have a problem with your computer, it's just having a hard time getting enough data to play the video's smoothly.
SOURCE: Whenever I play internet video (Hulu etc.,) it
for me, i download hulu videos to my computer with hulu downloader.
SOURCE: The videos play but stop every 2 seconds then play
Before we can give you any troubleshooting steps wanted to confirm
1. Are you playing online videos or from cds or DVDs?
2. When did the problem start ?
Thanks
proton
SOURCE: Long time buffering videos; video streams freeze
If a streaming video takes a long time buffering from Youtube or another website, it's because your internet connection is slow. If your video freezes up and jitters, that might be your internet connection and/or the video card is working too hard.
Go to this website and run the speed test for the city closest to you and let us know what your connection speeds are (download/upload). This will help us determine if the problem is the internet connection speed or something else:
http://speakeasy.net/speedtest/
SOURCE: You tube stalling every 3-5 seconds no contining
Try to uninstall the Adobe Flash Player Active X and Plug in and then reinstall it as there could be traces of previous versions in the computer which are interfering and making it difficult for the browsers to properly display videos on your computer. You can do this from the computer user settings and manipulating the "Add/Remove" programs list.
-- Try to use Flash Player 9 is your Flash Player 10 is not working fine. You can simply download it from the Adobe web site.
-- Update the drivers, the link is given below which would ask you to download the file through internet and run it on your computer.
-- The problem behind the Shockwave Flash crash could be your sound drivers. Follow these steps:
1) Open Device Manager
2) Look for the sound-card device
3) Note down the name for that device
4) Just uninstall the it.
5) After uninstalling restart your machine.
6) Your Windows 7 or Windows Vista would automatically download and reinstall the sound driver. You can also do it manually through approaching the sound card company's web site.
-- Fix your Windows Registry which is a highly recommended thing you should do to find a quick and reliable fix for common PC errors and crashes.use registry cleaner reg in out
