SOURCE: I have to replace the rings on the pistons does
try e-bay first. if you can't find it there google piston rings for your honda shadow vt500c.
SOURCE: How do I get to the piston rings on a 1981 honda xl 500 off
the cylinder will slide off the top of the piston, then you can replace the rings and slide the cylinder back down over the top of the piston. The bottom edge of the cylinder sleeve should have a small chamfer in it to aid in getting the rings into the cylinder.
SOURCE: How much can a 1996 Honda VT600CD engine safely be
Should be able to bore 50 to 60 thouthands without any trouble. Parts should be available thru Wiseco.
SOURCE: how to replace piston rings on honda 6 horse motor
you need to remove the pump then the end cover from the engine remove the cylinder head the unbolt the connecting rod push out the piston hone cylinder and then wash the motor out with soap and water i use tide clothes soap and hot water put it back to gether now why does it smoke check the head gasket the over head engines blow head gaskets and **** oil from the crankcase
