20 Most Recent Honda 6370C - Parallel Power Kit For EU3000i Questions & Answers
There is an upright small pencil diameter sized fuel screen inside the fuel tank of the EU3000is. I went in through fuel filler opening on the the top of the unit with a tooth brush on a stick and cleaned the screen. I then siphoned the rust and dirt particles out of the tank. Doing it this way precludes the necessity of draining the tank. My 3000 has been working smoothly since. If the problem reoccurs, repeat the process.
Honda 6370C -... | Answered on Oct 13, 2019
replace the 20 amp fuse that is inline to the starter. you will find it wired in above the battery.
Honda 6370C -... | Answered on Feb 11, 2018
Bad earth connection to the key switch as these magneto types only earth the coil wire to turn ignition off. Check for loose connections or faulty switch
Honda 6370C -... | Answered on Feb 07, 2018
First check the circuit breakers on the control/outlet panel.
Then take the end off the generator and look at the brushes (usually what breaks) and the 2 slip rings they ride on (these get dirty and have to be cleaned off with a bit of emery cloth)
Then look at the voltage regulator (the little board that the brushes plug into)
Let me know if you need more detailed help,
Carl
Honda 6370C -... | Answered on Nov 16, 2016
I'd say your battery in the generator is going bad or bad. They are very small and do not hold a charge for very long. The noise you heard was probably the starter shaft hitting the flywheel cogs. I doubt any harm was done as long as you did not repeatedly try to start it with the key. Why Honda put a battery in these is because they are intended for use in a campground setting, where they would be used on a daily basis and the battery would constantly charged. Whereas people like us buy them for emergencies only, they sit for long periods, and the battery goes flat, and the fuel clogs the carb and we get the surging issue. That's my 2 cents. When I brought mine home new, I Sta-bil'd the heck out of the gasoline, this past winter, on start-up, the unit surges. Of course the battery was flat.
Honda 6370C -... | Answered on Dec 17, 2015
Honda Engines Small Engine Models Manuals Parts Resources
They have all the engines there.
They don't however have the GX430 They have other models that might be close to yours.
Hope this helps.
Honda 6370C -... | Answered on Jun 07, 2014
I'VE SEEN THIS BEFORE ON 1 I REPAIRED IT IS THE INVERTER THAT IS BAD!!! THEY COST ABOUT $600.00 JUST FOR THE INVERTER!!!!
Honda 6370C -... | Answered on Jan 01, 2014
remove the throttle control motor spin motor a few times. I believe due to the minimal rotation required during activation a flat spot or build up results in a poor connection. Kicks down under load now. Back to the smoothnes of a new unit
Honda 6370C -... | Answered on Mar 17, 2013
Honda 6370C - Parallel Power Kit For  EU3000i Logo
65 questions posted
Top Honda Electrical Supplies Experts
John Trevino
Marvin
Marvin
Mike
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Honda Electrical Supplies
Most Popular Question
need owners manual 11 hp honda gx430
  • Electrical Supplies
