REMOVING SPARK PLUGS ON A 2002 LINCOLN LS
Generally in a spark plug is 60000 kilometers, if fuel is bad need in early, remove the spark plug, such as for auburn or rust color, spark plug showed normal; Such as stained with oil, shows that the spark plug gap imbalance or too much oil, high tension line short circuit or open circuit; Such as black smoke, spark plug type cold wrong or mixture is thick, the oil is up; Such as the top between the electrode and sediment, when for the oily sediment, shows that the cylinder into the oil has nothing to do with the spark plug, when the black sediment, spark plug carbon deposition and bypass, when grey sediments, is a gasoline additive covered electrode lead to lack of fire; If serious erosion, such as the scar at the top, with black pattern, electrode melt, showed that the spark plug is damaged.
hope help you -auto diagnostic tool
SOURCE: changing spark plugs on lincoln town car
Remove the spark plug wires, remove the spark plugs,replace them. Do this one cylinder at a time if you never did it. On that year you may need to remove the upper intake to access the plugs on one side. In that case go to a shop. This would not be a novice job.
SOURCE: 2002 LINCOLN LS V6 3.0 PCV VALVE LOCATION
it is down under the intake manifold. the intake manifold must be removed to get to it. this vehicle is known for developing a vacum leak in the elbow hose that connects to pcv valve, so ive done a few.
SOURCE: How do I change the spark plugs
You have to take the engine cover off, and then you should see the spark plugs on both sides of the engine. If you can't seem to find them, just follow the wires from the coil or distributor.
SOURCE: REPLACING SPARK PLUGS IN A 2002 LINCOLN LS
What type?
- Premium Class
Champion / Double Platimun / RC12PYP / GAP .044"
- Standart Class
Champion / Traditional Spark Plug / Part Number RC12PYP / GAP .044"
More details: http://www.championsparkplugs.com/
Good luck.
SOURCE: NEED ENGINE DIAGRAM FOR REPLACING
sorry no diagram but rather simple on either side of the engine there are plastic covers in the middle of the valve cover take that off to expose the coil packs disconnect them and the spark plugs are right there in the well i beleave a 5/8 deep well socket and a couple extentions and u should be good
The spark plugs in the v6 can become an involved job as the upper intake manifold. The LS uses a Coil on Plug (COP) ignition system, meaning that the spark plugs are located under the ignition coil
