I have a 1997 Mitsubishi Eclipse and everything works fine except the tail lights, the brake lights work, as do the head lights, but the interior lights nor the tail lights are working at all
If brake lights, there is a switch that the brake pedal pushes in to turn on the brake lights. The switch is easily adjusted, to where it is no longer depressed when the pedal is release.
there must be a short circuit which powers tail lights and brake lights. probably you have a dual filament bulbs which have both brake and tail light together. check for bulb, socket/or bulb housing and harness of that light.
If the metal tail light sockets are held into the tail light housing by screws and the ground wires for the tail lights are also held in place by the same screws. This is the source of your lighting problem, plain and simple bad grounding. It will cause tail lights to flicker , work , or not work. Check the ground wires and socket attachments carefully.
I've worked on these the first drove me crazy. its the turn signal switch every thing runs thru these. head lights, turn signal, brakes. except the third brake light. it runs directly from the brake switch. go figuare
96 eclipse rs back tail lites and dash wont come on i changed the combination switch ,fuses,relays and bulbs and it still dont work what else can it be?
