Spectroniq PDV-808 Logo
A
Anonymous Posted on Mar 29, 2013
Pdv-808 parts where do I find replacement parts to fix it?
1 Related Answer
Anonymous
  • Posted on Jan 14, 2009
SOURCE: broken disk lid
Not sure if you can find a replacement lid but you may be able to play DVD's if you manually depress the small switch that the lid would engage if it were closed. The switch is located where the lid hinges at the right side, you should see a small rectangular hole. The switch can be depressed through that hole. Of cousre, your DVD will be spinning with no lid to protect it but just don't touch it while the disc is playing. When done playing, you can just turn the unit off or remove whatever you used to engage the small lid switch.
Greg
My canon ir1024if has error 101 what causes it and how can i fix it
Error 101 is not listed. However 808 is and this requires you replacing the fuser assy. What do you mean "after the blow"??
Tengo problemas con el dvd no lee ningun disco
Hay un poco de problema con ese marca de fabrica.
Uno: el producto es de canada y fue hecho en 2006. Tonse el Firmware Necesita ser puesto al d?a.
Dos: El producto lla no lo asen tonse no vas a poder ponerlo al dia el firmware de tu dvd.
Los dvd de hoy usan diferente codigos tonse tu spectroniq no tiene los codigos de aqui pare que lee el dvd. Solo puede lee viejo dvd que conprates.
No hay nada que aser con tu producto.
Address of hyundai corporation in kuwait
http://www.hyundai-kuwait.com/locations.aspx
Location - Shuwaikh
Head Office
Timing: 8:30 AM - 6:00 PM
Tel. No. +965 1 808 444
Fax. No. +965 2 484 8035
Showroom
Timing: 8:30 AM - 12:30 PM & 4:00 AM - 8:00 PM
Fax. No. +965 2 483 9265
Location - Shuwaikh
Service
Timing: 7:30 AM - 4:30 PM
Thursday Timing: 7:30 AM - 1:00 PM
Tel. No. +965 2 483 1077
Fax. No. +965 2 481 7830
Quick Service
Timing: 7:30 AM - 7:30 PM
Parts
Location - Ahmadi
Showroom
Timing: 8:30 AM - 7:30 PM
Fax. No. +965 2 398 4363
Service
Timing: 8:00 AM - 6:00 PM
Thursday Timing: 8:00 - 1:00
Parts
Thursday Timing: 8.00 - 1.00
Location - Jahra
Service
Tel. No. +965 2 458 7926
Fax. No. +965 2 458 7929
Parts
Tel. No. +965 2 458 7927
Location - Shuwaikh Canadadry
Parts
Mob. No. +965 9 731 9237
Jan 19, 2011 • Cell Phones
DVD.My dvd player lcd screen is broken.How can I get it replaced?
HELLO
When an LCD or plasma screen is damaged - it's gone :-(
SORRY!
I NEED A BATTERY FOR MY PORTABLE DVD PLAYER MADE BY SPECTRONIQ
You will have to purchase a replacement battery from the manufacture or their authorized parts distributor. Don't waste time looking in electronics stores, because you won't find it there.
3answers
NEEDS AC ADP. CHARGER FOR A DURABAN PORTABLE DVD MODEL PDV-705
call alco electroninc at 1800 252 6123 they will tell you where to buy a new battery.
Broken disk lid
Greg
PDV-808 Disc Not Spinning
can you see on the optical lens if the lights goes on.. if the red lights on.., problem is int he flex cable/cable wire/ or what so ever term use by the manufacturer.. posible also defective optical lens. or try to re adjust the trimmer on thier circuit.. tnx
if problem persist desame you may contact to the qualified technician.
3answers
Protron PDV 388 DVD Player
Plug in A/C adaptor to ubit and with unit off, see if you can get a voltage measurement from the terminals that connect to the battery. If voltage is present, dead cells in battery. If no voltage present, suspect switching regulator. These units are hard to service due to parts availablity and cost of a replacement unit vs shop labor and parts charge.
Top Spectroniq Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you a Spectroniq Televison and Video Expert? Answer questions, earn points and help others
