20 Most Recent Spectroniq PDV-808 Questions & Answers
Hay un poco de problema con ese marca de fabrica.
Uno: el producto es de canada y fue hecho en 2006. Tonse el Firmware Necesita ser puesto al d?a.
Dos: El producto lla no lo asen tonse no vas a poder ponerlo al dia el firmware de tu dvd.
Los dvd de hoy usan diferente codigos tonse tu spectroniq no tiene los codigos de aqui pare que lee el dvd. Solo puede lee viejo dvd que conprates.
No hay nada que aser con tu producto.
Spectroniq... | Answered on Mar 09, 2011
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Spectroniq... | Answered on Jan 25, 2011
You will have to purchase a replacement battery from the manufacture or their authorized parts distributor. Don't waste time looking in electronics stores, because you won't find it there.
Spectroniq... | Answered on Jul 04, 2009
Not sure if you can find a replacement lid but you may be able to play DVD's if you manually depress the small switch that the lid would engage if it were closed. The switch is located where the lid hinges at the right side, you should see a small rectangular hole. The switch can be depressed through that hole. Of cousre, your DVD will be spinning with no lid to protect it but just don't touch it while the disc is playing. When done playing, you can just turn the unit off or remove whatever you used to engage the small lid switch.
Greg
Spectroniq... | Answered on Jan 14, 2009
can you see on the optical lens if the lights goes on.. if the red lights on.., problem is int he flex cable/cable wire/ or what so ever term use by the manufacturer.. posible also defective optical lens. or try to re adjust the trimmer on thier circuit.. tnx
if problem persist desame you may contact to the qualified technician.
Spectroniq... | Answered on Oct 04, 2008
go into settings, click tuning, zone ,analog or digital, click start, will download channels if present.
Spectroniq... | Answered on May 04, 2018
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
Spectroniq... | Answered on Nov 24, 2016
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Spectroniq... | Answered on Aug 05, 2016
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
Spectroniq... | Answered on Apr 15, 2016
Universal remotes can be bought in most electronic stores, Big Department stores or ordered online. See links below.
Show your gratitude and press the helpful button and follow me on fixya for more tips and info.
https://www.google.ca/aclk?sa=l&ai=Cjk7tPCTFVsfXHYXtpAPMy7aID5T_lccH3PXs6d0C0K3MCQgAEAFg_bCYgegDoAHa4Pj9A8gBAakC77WLpYWDqD6qBCJP0L_6r_44mIPVZ2NdYmgT-qo_YFfZ7QScZX8JG-YfBWNfgAeOn4cCkAcBqAemvhvYBwE&sig=AOD64_0ulvlP98B1rW_jH8OcZd7NFUhpMg&clui=0&q=&ved=0ahUKEwj8ka2hmoDLAhXmtoMKHVpEC_wQ0QwIGQ&adurl=http://clickserve.dartsearch.net/link/click%3Flid%3D43700007524302597%26ds_s_kwgid%3D58700000579323988%26ds_e_adid%3D93733534644%26ds_e_matchtype%3Dsearch%26ds_e_device%3Dc%26ds_e_network%3Dg%26ds_url_v%3D2%26language%3DEN-CA
https://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&sqi=2&ved=0ahUKEwjctJjmmoDLAhVJlYMKHdugAeIQFggcMAA&url=http%3A%2F%2Fwww.walmart.ca%2Fen&usg=AFQjCNGUg9P_2ah-D9uNan41nmBewXkaAg&bvm=bv.114195076,bs.1,d.amc
https://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=10&cad=rja&uact=8&sqi=2&ved=0ahUKEwij5pnymoDLAhUouoMKHenjBp8QFghCMAk&url=http%3A%2F%2Fwww.bestbuy.ca%2F&usg=AFQjCNFUFW_nmgr3xSbQPhCvTc9zkBEO-w&bvm=bv.114195076,d.amc
https://www.google.ca/aclk?sa=l&ai=COF4JDiXFVoepFImepgPkt4DgBJnnlewHyZzEta0CnsCCBggAEAFg_bCYgegDoAH90sr2A8gBAakC77WLpYWDqD6qBCFP0IIhy12nRo9Vh3eLkjle8Pkiyk5K19ua4uyoZWGbmZaAB7mqrAGQBwGoB6a-G9gHAQ&sig=AOD64_14LskVDI7V3nMtMjHhuBf_finEGw&clui=0&q=&ved=0ahUKEwiq3rSFm4DLAhUBvYMKHeLbB5wQ0QwIGQ&adurl=http://pixel.everesttech.net/4202/cq%3Fev_sid%3D3%26ev_ln%3Dsears%2520outlet%26ev_lx%3Dkwd-12623902%26ev_crx%3D80881039801%26ev_mt%3De%26ev_n%3Dg%26ev_ltx%3D%26ev_pl%3D%26ev_pos%3D1t1%26ev_dvc%3Dc%26ev_dvm%3D%26ev_phy%3D9001059%26ev_loc%3D%26ev_cx%3D161042401%26ev_ax%3D7576498801%26url%3Dhttp://www.sears.ca/outlet%253Fextid%253D250913_ca_1search_2en_3gogl_4outlet_5en-sears-outlet-brands-e_6sears-outlet%2526s_kwcid%253DAL!4202!3!80881039801!e!!g!!sears%252520outlet
Spectroniq... | Answered on Feb 18, 2016
Spectroniq PDV-808 Logo
Popular Tags
9 questions posted
Top Spectroniq Televison & Video Experts
Charles Tidwell
Chinmay Joshi
Chinmay Joshi
Are you a Spectroniq Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Spectroniq Televison & Video
Most Popular Question
tengo problemas con el dvd
  • Televison & Video
