reset switch for 2004 land roverreset switch for 2004 land rover
AnonymousMar 26, 2014
What does the orange dash light with the symbol (0) on my 1992 Range Rover mean?What does the orange dash light with the symbol (0) on my 1992 Range Rover mean?
You can't post conmments that contain an email address.
The ignition system is controlled by the ECM. Check power at fuse box in on right side under dash. Check fuses right side engine compartmentlower dash panel if all OK check power to ECM located right side "A" pillar in alloy box. this unit could be faulty if no spark at coils, assuming they have been connected correctly. may have to get tested for codes at L/R dealer or someone with test tool. Another source of problem may well be flat battery in transponder key. The indicator light on the dash willflash rapidly for 10 seconds if the vehicle has been unlocked with the remote and the drivers door is opened if the battery in remote is getting low
The red light means the Immobiliser has not been turned off, the deactivator in the key must not be working correctly, visit your local land rover dealer who will be able to make sure the key is paired to the car correctly, otherwise you may need a new key.
i have same probleme with my land rover, this trouble is intermitant wath can i do abs light traction control andhill descent if you have he ansher for me [email protected] thank you
Your "s" light is probably surrounded by something that looks like a gear. If that is true, then you have selected sport performance of the transmission. To deselect the sport option, look near the bottom of the gearshift and you shall see a button that says "mode", press that button and the light should extinguish.
