SOURCE: A large black box appears in the center of my
Keep pressing CC button on your remote control until you see CC/TEXT OFF.
Testimonial: "The CC was definitely the problem!! Appreciate your help....wow...this site is great! Thanks agai!"
SOURCE: sharp aquos turning tv on green light comes on
Unplug it from the wall for about an hour to see if it will reset itself fist, if it is still the same then you need to look inside. First thing to look for are the DC filter caps in the power supply module, then check the DC output voltages.Look burnt brown hot spots on the circuit boards.
If you are going to DIY and have proper tools, knowledge of electronics and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
SOURCE: no sound on my sharp aquos lc-45gd4u 45 in
Assuming you are using the internal speakers, check and make sure you have the audio enabled. Some TV sets have a option to turn off the internal speakers. Also make sure mute isn't turned on. If you are using external audio setup, double check your connections.
SOURCE: picture and sound go out on my 60" sharp aquos tv
Check its sound settings first. If it is OK, check its speaker. If you wish to get more details about these type of faults, check this link. Pull up older posts there.
