SOURCE: leviton slide dimmer switch w/locator light light comes on but doesnt dim
What sort of light is it , dimmer switches normally only work on Incandescent type lights not flourescent type.
Otherwise it sounds as if the dimmer function is faulty.
SOURCE: touch dimmer malfunction
sounds like a loose connection to me, check to make sure all connections are tight. sometimes the bulbs themselves don't make a good connection in there socket.
u will have to take the switches out of the wall box and make sure the wires are tight, whether they are on screws or wires connected to wires. if it is wires to wires u may have to take that apart to make sure u don't have a bad connection there.
if it is none of that, then it is time to replace the switches
SOURCE: two wall sconces: pulled out old dimmer: 2 sets of
Okay. This is going to be easy.
You're in the middle of a circuit and that's why you have 2 Romex'.
The HOT black is the line side. It comes from the panel. The not-hot black is the load side. These 2 blacks go to the brass screws on the switch. The whites tie together and don't go to the switch, UNLESS there are 2 silver screws on it, then they go there. Watch the switch to see if it's clearly marked for LINE and LOAD. In that, the HOT black goes to LINE and it's white companion (from the same Romex) goes to the LINE silver screw. The 2 from the second Romex go to the screws marked LOAD.
In the sconces, you're going to find one that has 2 sets of wires and the other has one set. (I'm betting) The one that's working better, is the first one from the switch wiring.
Open the working one with the switch turned off, of course. Disconnect the wiring going to the second light. Make sure the first light works just like you want it to.
Now, take the 2nd sconce down and see if the wires are in the right places. White to white, black to black, grounds in place, protecting wires from the others. If all that looks fine, reconnect the wire running from the first light to the second. Even though these are still opened up. turn on the switch and see if the 2nd sconce works.
If it's still buzzing, try to determine exactly where the noise is coming from.
Some dimmers won't work with florescent bulbs, some don't like halogen bulbs. SOME don't like the energy-efficient curly bulbs!
The box/instructions for the new dimmer may point out what it's NOT compatible with.
If everything's connected correctly and there's still buzzing, I'm guessing that there's some mis-match between the new dimmer and the lights.
SOURCE: new Leviton 'lighted, decorative' switch flickers when off
Personally, I've had no practical problem using the standard lighted switches with CFL bulbs but I am willing to put up with the flicker as the switches are in an unimportant area. The reason why they flicker is each CFL bulb has an electronic circuit in the ceramic base so you don't have to install a balast circuit in every lamp and fixture in your home. This is also why they cost more. You are basically throwing away a complete flouresent light fixture when you change these bulbs. Anyway, the reason the switches flicker is that there is a capasitor in the circuit that keeps charging and discharging through the little neon bulb in the switch. I had a CFL bug light on my back porch and when I was outside looking at the stars at night, I kept seeing something out of the corner of my eye. I stared at the bug light for a while and it was flashing every few minutes as the high voltage circuit in the bulb would charge to it's ignition threshold then fire the bulb and start the cycle all over again.
Good luck.
Jeff
SOURCE: I have a dimmer switch
Hello.
Had this problem my self a while back, here's what I found out. Firstly, it may simply be the switch is faulty. If this was a new install, take it back and try another. But before that, get all relevant information about the lights you are dimming. Here's why: Some light fixtures are incompatible with dimmers. They may dim - but not properly. Some lights/fixtures require specific dimmers to be used: incandescent or not, total wattage in fixture, and so on. Having this information may save you a trip if it's actually not the switch. Good luck.
