HP G60-438NR (NW150UA) PC Notebook Logo
Michael Lynch Posted on Mar 18, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wont boot boots to a blank screen with a cursor in the upper left corner cant boot into safemode or to cd cant get into bio either never get a bios screen
max carson
Level 3:
  • HP Master 7,627 Answers
  • Posted on Mar 18, 2013
max carson
HP Master
Level 3:
Answers
7627
Questions
Helped
1015282
Points
21773
Remove ALL media, DVD,CD, USB, etc. Unplug, remove battery, plug in, reboot. If that fails, reseat the Memory Mods. Replace the CMOS battery, remove HDD and test.
5 Related Answers
Mike Lange
  • 136 Answers
  • Posted on Jul 08, 2009
SOURCE: Black Screen with Blinking dash on upper left corner
Are the xp disks specific for that computer. The reason I ask is because when you changed the hardrive none of the components on your computer know what to do because you won't have any drivers.
Does your hard drive lights come on? Do you think the computer is trying to access your disk drive
Anonymous
  • 17 Answers
  • Posted on Jan 08, 2009
SOURCE: boot up problem
HI,
There might be a problem with your cmos/bios setting. Try to set to defaults first.
the bios/cmos menu can be entered by pressing del or F2 or F10 keys during power on (before windows logo appears) depending what type of notebook.
find the boot devive or boot sequence,
select CDROM as the first boot ( or first line)
Save and reboot
good luck
Anonymous
  • Posted on Feb 01, 2009
SOURCE: New HDD inserted into Pavilion ZD7000 - will not boot from XP CD
Try your old HDD in it and see if that works. If it does work then nothing is damaged except your DVD drive/Controller. Try putting the new HDD in another computer, installing windows then putting it back in the HP. If all else fails then flash the bios with an updated image and see if that rectifies the problem.
Anonymous
  • 104 Answers
  • Posted on Jun 09, 2009
SOURCE: HP Pavilion ZD8000 No CD Boot
replace the ODD and try with another cdrom.
TechyDrood
Justin
  • 2072 Answers
  • Posted on Sep 01, 2011
SOURCE: How do I boot from an external CD? The BIOS offers
The HP Mini are kind of odd, the external CD/DVD or usb drive will only show in BIOS after you plug it in, power it on and then reboot. Then go into BIOS and it should list it in boot priority list. Move it to the top and reboot and it will boot from CD. Also you can press F9 instead and it will let you select the boot device.
Comment back if you need any more help.
When I push the power button, the main dell start up screen comes on followed by a black screen with a blinking cursor in the upper left corner. It uses Windows 7
Remove any CD's or USB drives 1st.
Sound like its trying to load and can't find hard drive, CD, or USB device. You need to go into BIOS by pressing an F key during boot. Look on the screen for correct Function key to press during boot. Make internal hard drive first. Save and restart. Reseat hard drive if it does not show up in BIOS.
It wont boot, goes to black screen with whit blinking dash
Yes, this sounds like the traditional black screen issue, but it's different! This machine is a Dell Dimension 3000 with XP. System won't boot. After Blue Dell BIOS splash screen with F2 & F12 options, it just goes black. There will ultimately be a white cursor in the upper left hand corner. I can edit BIOS with F2, I can get in to the boot menu with F12, but I can't do anything after that. I can even get in to the Safe Mode menu (F8), but it never boots.
I turn on the power button,it shows ' acer ' and 'F2 and F12' dialogs. The hard drive light is on at this point, butthen the light flickers and goes out and the screen only gives me a blinking cursor in...
Check you do not have a disc in the CD drive or a USB drive connected.
Check the BIOS has the boot order correct, select the hard drive as the first drive to boot from.
If that does not fix it you will need the OS CD and change the boot options to boot from CD first, and try to recover the data.
3helpful
2answers
My laptop Preasario cq61 has the black screen problem, when it starts it shows the first screen fine ( the one where you can hit ESC to enter the bios) after that it goes black and in the top left corner...
http://h10032.www1.hp.com/ctg/Manual/c01141784.pdf
OK download that service manual, follow the troubleshooting procedures and you will sort your problem out in now time, i have a hunch, that your HDD, is faulty... and may need replacement. Anyway Download and use that manual, it's a generic one.. but will still work for you.
Was installing hp starter disk 6500 into dell4550 dell was terned off my mistake and now wont re-boot just blank screen with small light flashing were fast upper left corner of screen
Enter the system bios and set the boot order to boot from CD ROM. If this order is correct and you are still experiencing the same issue. Re-enter the bios and set it to default setup. However, enter the boot order and ensure the CD-ROM is the first boot device and Hard Drive is the second.
Enjoy the power of a PC
1helpful
2answers
Have a problem with Optiplex 755 where i got a virus and now i cant use f2 to get to seetings, i cant use f12 for boot options, and i must not have cd in boot order, because the win7 cd wont boot on...
You could take the CMOS battery out of the motherboard, unplug the power cord and hold the power button in for about 20-30 seconds. Plug it back in and turn it on without the battery in it and it should come up with the bios. Turn the machine back off and reinstall the battery. When you turn it back on you should be able to press F2 for setup or F12 for the boot menu.
1helpful
I am trying to replace the hard drive in my compaq evo n1020v. The problem I am having is that when I turn on the computer, it doesn't seem to be booting from the windows CD. It just sits there and does...
you need to set the jumper setting from your Hard Drive as Master Drive and the CD/DVD player is Slave then go to Bios settings then set 1st boot CD/DVD to boot the windows installer..good luck and have a nice day..
2helpful
Black screen and in the upper left corner there is a cursor theat is blinking ... and teat is all
It sounds like a problem loading the operating system. Try booting from an installation CD to see if anything comes up... if it loads from the CD, there could be a problem with your hard drive.
When it turns on, try entering the BIOS by pressing the correct key (usually DEL, F10, F12, or F2) Make sure that the boot device is set to your hard drive. If you do this and it loads with an error saying 'insert boot media' or 'boot device failed' you'll have to either try fixing your boot sector (which can get tricky, but I'll walk you through it if you really want to attempt it) or a much easier fix, reinstall the operating system.
Toshiba won't boot
 You can boot from XP cd.
When prompted..press [R] this will launch recovery console.
Choose your windows installation (typically by pressing [1] press return..
When prompted for password type chkdsk /r
Press return..Windows will fix errors..type Exit and press return..
Let me know if that helps.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
