20 Most Recent Gateway LT2001u Netbook Questions & Answers
https://support.microsoft.com/en-us/help/17144/windows-10-change-desktop-background
Gateway LT2001u... • Answered on Dec 09, 2017
Did you try PASSWORD as your password. If this doesn't work and you have common knowledge of the inside of a computer, remove the CMOS Battery ( common 2032 watch battery) for a few minutes this will reset the the motherboard and the BIOS. but if this is any type of IBM or Lenovo you may have to call the manufacturer to resolve this problem
Gateway LT2001u... • Answered on Dec 18, 2013
some one must have put in a boot password to your laptop, follow this: When booting up, enter your BIOS setup (usually by pressing the F2 key at the appropriate time). Locate the BIOS Password section and turn the ON STARTUP password to off. There is no standard setup for BIOS, so I can't give you exact instructions. If this does not work, try: remove cell & start your pc you will here beep...beep...beep... then turn off your pc & restore your cell.Start your pc and password is removed. there is a battery on motherboard,a button cell,you can try removing that and start computer, then put it back, bios settings will be lost. you can also try removing any hardware like ram,if you have two,when system is off,turn on , it will prompt for changes , enter bios and try remove password.
Gateway LT2001u... • Answered on Dec 15, 2013
If your Operating system is Windows 7, right click your current desktop, choose the Personalize, double click the Desktop Bacground, choose Browse, and browse to the folder that has the picture you want to use for the desktop background, click OK button. All the pictures on the folder is displayed. Click the check button on the picture you want to use and save the setting.
Gateway LT2001u... • Answered on Dec 30, 2012
At this point you would be further ahead replacing the netbook.
Gateway LT2001u... • Answered on Mar 05, 2012
Yes, this sounds like the traditional black screen issue, but it's different! This machine is a Dell Dimension 3000 with XP. System won't boot. After Blue Dell BIOS splash screen with F2 & F12 options, it just goes black. There will ultimately be a white cursor in the upper left hand corner. I can edit BIOS with F2, I can get in to the boot menu with F12, but I can't do anything after that. I can even get in to the Safe Mode menu (F8), but it never boots.
Gateway LT2001u... • Answered on Aug 14, 2011
Hi there and welcome to Fixya!
I'm guessing you're referring to the Windows desktop background. But if not, please provide additional information.
The Windows desktop background is the image on the desktop that appears behind the shortcuts. To change the background, please follow the steps below:
1. Open the "Display Properties" screen by placing the mouse cursor over a blank area of the desktop. Click the right mouse button to access the context menu and choose "Properties". You can also access the "Display Properties" screen by clicking on Start, select Control Panel, and then Appearances and Themes. Open the "Display" shortcut.
2. Select the "Desktop" tab from the "Display Properties" screen.
3. Pick a picture from the Background list by clicking on it and click on "Center, Tile or Stretch" to select the position. Personal pictures in the "My Pictures" folder are listed by name in the Background list.
4. Choose a background picture in another location by clicking on the "Browse" button. You can use any files with the following extensions: .bmp, .dib, .gif, .htm or .jpg. Click on "Center, Tile or Stretch" to select the position.
Gateway LT2001u... • Answered on Jun 29, 2011
If you have a USB flash drive, you can download the operating system files onto it and insert that into the drive.
Gateway LT2001u... • Answered on May 10, 2011
Give it time to charge and try again. There are power setting that may be shutting down the machine at less than 10 or 5 % charge.....
Gateway LT2001u... • Answered on Mar 16, 2011
If the external monitor works - The problem is in the screen or cabling of your Laptop
--> Needs to replace.
Minor change but anyway:
If the extenal monitor has same challenges the problem is in laptops motherboard and actually in display card which normally is integrated
Gateway LT2001u... • Answered on Jan 06, 2011
Try restore pc to factory setting. here is the way : http://support.gateway.com/s/software/microsof/Vista/7515910/7515910su12.shtml
Or follow this without picture is the same info:
Restore from Factory Default
The Factory Default installs a new copy of Windows Vista™ on the computer. The installation restores the computer back to the factory installation of Windows Vista with all the drivers and programs that originally came with the computer.
Notes:
  • Be sure that you back up your data files before performing this option. All of your personal data files and applications are erased during the recovery process.
  • Due to the large number of virus and Spyware threats on the Internet, it is recommended that you disconnect all Internet connections before performing the recovery. After the recovery, antivirus and firewall software can be installed, and then the Internet connection can be re-enabled to update the antivirus definitions and perform Microsoft® Windows Updates.
  1. Remove all CDs or DVDs from the optical drives.
  2. Turn off the computer, using the normal Windows shut down process.
  3. After the computer is turned off, disconnect all USB devices except the keyboard and mouse. This includes USB devices such as a printer, scanner, removable storage, or camera.
  4. Turn on the computer. After the Gateway BIOS logo appears, press ALT+F10. The easiest method is to hold down the ALT key and repeatedly press the F10 key. Note: There is no prompt to press Alt+F10.
  5. Windows loads files.
    View Picture
  6. The Please wait a moment screen is displayed.
    View Picture
  7. In the Restore from factory default dialog box, click Next.
    View Picture
  8. In the Destination Disk Information dialog box, click Next.
    View Picture
  9. In the Notice dialog box, click OK.
    View Picture
  10. The hard drive partition is created.
    View Picture
  11. The factory default installation is copied to the hard drive.
    View Picture
  12. In the Finished dialog box, click OK.
    View Picture
  13. The Please wait a moment screen is displayed and the computer restarts.
    View Picture
  14. Windows prepares to start for the first time. This may take a few minutes.
    View Picture
  15. Windows continues setting up the computer.
    View Picture
  16. The computer restarts.
  17. In the Set Up Windows screen, click Next.
    View Picture
  18. In the Please read the license terms screen, select the I accept the license terms check box for each item, and then click Next.
    View Picture
  19. In the Choose a user name and picture screen, enter the appropriate information, and then click Next.
    View Picture
  20. In the Type a computer name and choose a desktop background screen, enter the appropriate information, and then click Next.
    View Picture
  21. In the Help protect Windows automatically screen, click Use recommended settings.
    View Picture
  22. In the Review your time and date settings screen, select the appropriate settings, and then click Next.
    View Picture
  23. In the Select your computer's current location screen, click the appropriate option.
    View Picture
  24. In the Thank You screen, click Start.
    View Picture
  25. Windows checks the computers performance. Depending on hardware, this process can take up to 15 minutes to complete.
    View Picture
  26. Windows prepares the desktop.
    View Picture
  27. The Gateway Recovery Management is installed.
    View Picture
  28. Installation is complete.
Gateway LT2001u... • Answered on Dec 23, 2010
Hello.
Either you have a memory issue or operating system problem.
First, disconnect all cables. Be certain to dispel static electricity by touching metal. Remove the memory cover. Try reseating (removing and reinserting) your memory (try one module at a time to test).
If still a problem, boot your system to Safe Mode (press F8 repeatedly). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, everything, including your documents and other files you saved on the hard drive, will roll back to that date.
If still a problem, the last choices are Factory Restore and reinstall. Accessing Factory Restore (restores to the factory settings and will wipe out anything that you have installed or saved on your PC), is dependent on your hardware manufacturer. Boot your system and press F10, F11, Alt+F10, or Ctrl+F11 to access Factory Restore. Follow the prompts.
If still not resolved, you'll probably need to reinstall your operating system.
Hope this resolves your problem.
Gateway LT2001u... • Answered on Nov 30, 2010
Can you access your BIOS when you turn on the computer?
Somewhere in the BIOS you may have inadvertently changed the netbook to boot from the "Network via PXE" instead of from your local hard drive.
To enter the BIOS, you must restart the PC and enter BIOS setup or BIOS features by pressing Delete or another hardware specific key on BIOS screen startup.
From there, you should encounter a series of menus that you can navigate only with the keyboard... not the mouse. With luck, you will find a boot menu option that you can correct.
Make sure you save your choices on exiting and restart your PC. With a little bit of trial and error, you should be able to coax your netbook to boot from its internal driver.
Gateway LT2001u... • Answered on Sep 09, 2010
To change the background on Windows 7 is pretty simple. Firstly, right click on the desktop and click on Personalize.
There are many images here to choose from or you can choose your own image by clicking on the Desktop Background link at the bottom of the Personalization window.
Gateway LT2001u... • Answered on Mar 16, 2010
If you lapto is in warranty, you can contact Gateway company itself. They can replce it.
Gateway LT2001u... • Answered on Mar 11, 2010
Gateway LT2001u Netbook Logo
Popular Tags
40 questions posted
Top Gateway Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Prashant M
Prashant M
Michael Thomas
Michael Thomas
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Gateway Computers & Internet
Most Popular Question
no way
  • Computers & Internet
