SOURCE: My son gave me his old olympus D-425 camera, but
http://www.olympusamerica.com/CPG_SECTION/cpg_archived_product_details.asp?id=1154&fl=8
Testimonial: "Thank you, I now will start my new hobby!"
SOURCE: The digital zoom capability has
You can try a few things to get it working again. If you're lucky, it's just dirt, lint, or a sand particle that's obstucting the lens. This blog delineates the steps you can take to try to free it up.
If none of them work, the camera will have to be disassembled completely to figure out the problem, and if you elect to have it serviced, it can run a bit. Try these steps, and hopefully you will have some luck with them:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Even though the article says "lens error", it applies to stuck lens assemblies, and the zoom functions.
It's also possible that the zoom lever switch is broken, but again, the camera has to be taken apart to discern that.
Anyway, good luck, hope this helps, and thanks for using FixYa.
SOURCE: Olympus SP-350 Digital Camera ZOOM ERROR
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need
any further assistance. Also, please be so kind to let me know if you
found this helpful.
Regards
Andrea
