Hi, I recently got a celsius R610 system and I want to install server 2008 on it but I cant find any drivers for it. Any help? Thanks in advance.
That system has support for windows XP and Linux (RedHat and SuSE) so if you want to install windows server 2008 you will need windows 2008 compatible drivers, maybe this link bellow can help you to identify right drivers (It is detailed technical motherboard manual for that system)
Manual
SOURCE: Hello, i have a Fujitsu
In order to fully install windows you need to have the driver loaded for your SCSI controller built into the mother board. Here: http://support.fujitsu-siemens.com/com/support/downloads.html is the website to get the SCSI drivers. Just make a floppy disk with them and when you load windows setup from the disk when it asks you to press F6 to install third party drivers do so. Then just point to the disk and load them up. When windows finishes loading the rest of the drivers and starts the setup process your hard disks should now be accessible.
SOURCE: operating system not found
If it only shows it sometimes then theres a chance your hard drive is failing. It may also be that there is a disk in the drive that the computer is trying to boot off.
If there are any strange clicking noises coming from the box then it will be the hard drive.
SOURCE: I installed on my celsius R610 windows 7, no
You may need to enable it in bios, maybe with the new os you need to update the chipset drivers or bios!
SOURCE: Celsius R610 orange light blinks continuously. Overheated?
First, is it clean, open case and check for dust. Clean fans , CPU , etc., if necessary. Open Task Manager , What is you Preformance, CPU % Memory %? What is running in Processes? Here is a little free program to adjust fans: http://www.filehippo.com/download_speccy/ The orange light is it the HDD led? You can use CCLEANER free: http://www.filehippo.com/download_ccleaner/. You can clean the junk from your system and in TOOLS, STARTUP, Disable ALL unnessary programs from startup, that will speed up your system.
