First, is it clean, open case and check for dust. Clean fans , CPU , etc., if necessary. Open Task Manager , What is you Preformance, CPU % Memory %? What is running in Processes? Here is a little free program to adjust fans: http://www.filehippo.com/download_speccy/ The orange light is it the HDD led? You can use CCLEANER free: http://www.filehippo.com/download_ccleaner/. You can clean the junk from your system and in TOOLS, STARTUP, Disable ALL unnessary programs from startup, that will speed up your system.
Thanks for your solution attempt, Max.
Actually, what has helped eventually was an update of the system's BIOS. The PC was clean inside, the fans worked fine. The orange LED in question is marked with an envelope. HDDs work fine. I suspect the power unit to be a little on the weak side... No unusual processes or alike. Hey, and after BIOS upgrade to 1.05 the second XEON chip also was detected. So everything was fine. Again, Thanks a lot for your help! -- rooster2
Hope I was os so assistance. The orange LED, envelope, maybe it's list red here:http://uk.ts.fujitsu.com/rl/servicesuppo... ......Cheers.
