The problem with it is that when I plug it into a socket the light comes on and it makes a low buzzing noise after a few mins it starts to make a louder noise and the top of it feels warm. It's almost like a fan (if any) needs lubricating and then after another few mins it stops making noises and it doesn't do anything.
SOURCE: delonghi de 220 dehumidifier tasciugo
http://www.manualnguide.com/download/manual-guide/
delonghi-de500p-dehumidifier-owners-manual.html
The above URL will allow you to download instruction manual if a PDF format.
SOURCE: Kenmore Dehumidifier fan runs, compressor buzzes and quits
sounds like the compressor is seized.
SOURCE: my fedder dehumidifier m7dh45b2a makes an annoying noise
This noise is the vibration from the compressor...sometimes things can come loose and magnify the noise...check for loose parts and tighten as needed...
The compressor may also be going bad...
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
SOURCE: The dehumidifier is making a
your fan is possibly hitting something didyou drop it or bang into it you should have some one like a tech. to checkit out and PLease stop using it till you do this you could be damaging this unit even more than it allready is
SOURCE: I have a Delonghi DH250R dehumidifier.It make a
There are 5 basic, but solvable reasons for what you described. Please pay particular attention to numbers 1& 2..
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air
temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If
none of the above solves the problem, it may be a case of the
compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are
5 years old or older. It's rare in a unit younger than that. But, it
can happen.
I hope this helps you to further troubleshoot & solve the problem. Thanks for choosing FixYa.
Testimonial: "Thank you very much, I will try all the 5 steps and see if it work or I might have to buy a new unit"
