When i work without the charging pin on the lap top .It give a message battery needs replacement.Other wise it works ok with the power plug in.
SOURCE: My Compaq Presario C500T lap top won't start
Generally speaking, an orange power light indicates problems with the power. You also described to a "T" how a bad battery behaves. To test this theory, take out the battery and plug in the laptop. It should power up and run. If so, it's time to invest in a new battery.
To be doubly sure, if you have anyone with the same laptop as yourself, plug in their battery to your laptop. It should work if their battery is good.
Thanks for using fixya.com. Please rate this tip accordingly if it provides the information you needed.
SOURCE: there is power in the laptop.
if you say that either the battery nor the adapter was tested and seemed working fine but not actually giving power to the laptop itself then the problem is the motherboard from your laptop i m afraid
sorry i have no idea about the service center in tamilnadu
SOURCE: Battery not charging; what's the price for a new HP Pavillion dv6000 battery in new delhi?
hi there, if you need to replace the battery hun, the best places to check would be the internet on ebay possibly, or lookup laptop batteries with your model number, most places will not have a problem shipping to you, and usually have a single charge or a 1 time shipping charge no matter how much you buy, it is just a matter of comparing rates and if you want a warrenty, and try hp website, that will be good if your unsure about where to go, cuz if anything happens durring shipping the companay will replace it, another thing you can check is hp websites to find a legite representative for the company....thats about all i can help you with.....good luck hun and hope this helps you....shia
SOURCE: charger not charging battery and no powering lap amilo pro 3515
Your power connector on the laptop has been bumped too many times and the solder connection has worked it's way loose.. somewhat of a common annoyance. Find a good TV Repair shop, maybe a reputable PC repair shop and tell them to please resolder ( better to replace, but could cause rejection if they don't have a source for micro parts ) the connector back onto the motherboard.. could cost you $100 because of what it takes to access the location for a 1 minute solder job.. sad but true, sometimes, EVERYTHING in the laptop has to be removed to solder the connectors on the bottom side of the motherboard, sometimes you can get lucky with bottom side access. Get someone experienced in circuitboard soldering techniques. A hobbist will burn up more than what they are attempting to fix.
Toby White-Beebe
Dell Certified Lead Systems Expert
Testimonial: "thanks souds like that is the problem"
SOURCE: battery meter is low, even though computer is always plugged in
My first reaction would be that you have simply worn the battery out already and it can no longer hold a charge. Discharging and re-charging constantly will do that even in a year. Or leaving it plugged in 24/7 for week at a time can hurt it as well.
Sometimes if you run it all the way down to nothing/as dead as possible and then charge it back up it will "re-train" the battery where dead and fully charged are.
In the case of this battery it sounds like it's just worn out. Sometimes turning off extra features like bluetooth if it has it or the WiFI card along with dimming the screen when possible will get a few more minutes out of it.
I'm going through something similar with my laptop right now. I found a "universal laptop battery" and just carry that around now (amazon is a good place for such batteries). It was only about $30 or so. Sorry it's not good news!
Chris thank you i will try that ASAP.
