I think the black thing inside the port is broken cause its not turning on but if i put a another full charged battery in it ,it turns on . the problem is the broken charger port and i cant bother to replace it , it cost to much , and laptops are a pain to take apart i got it to work a few times but the pin has to touch the metal inside the port for it to turn on (if the pin touches the metal inside the port and white light at the bottom of the laptop comes on) couldnt get a charger with longer pin so it sends power to the laptop how can i fix this?
A) You don't want to take the laptop apart.
B) You don't have the money to have it repaired.
C) Keep going like you are with fiddling with it, and you'll smoke the AC adapter (Charger), and Power MOSFET's on the motherboard.
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
What !O_O! sort of 'miracle cure' are you expecting?
If you wish to correctly repair the laptop, this is the place.
Rig it so it works temporarily, and maybe permanently damages it?
Suggest go to another website.
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_inspiron_laptop/inspiron-1545_service%20manual_en-us.pdf
Charger Board
http://www.ebay.com/itm/ORIGINAL-DELL-INSPIRON-1545-DC-POWER-JACK-CHARGER-BOARD-00829-/170995370099?pt=LH_DefaultDomain_0&hash=item27d01e4873
You're going to need one of these, and connect it's alligator clip to a good ground source,
http://www.radioshack.com/product/index.jsp?productId=2103245
Doesn't have to be from that store. It's just an example.
Average cost is $3 to $6.
http://www.insidemylaptop.com/replace-keyboard-dell-inspiron-1545-laptop/
Need guidance? I'm right here. Post back in a Comment.
I'll step by step you through it.
Regards,
joecoolvette
im not from america ._. so its hard and expensive to repair it i brought it to a repair and it cost $50,000 JM (jamaican money) for the new solder and thats with the cost of repair excluded ._. thats like buying a new laptop and i dont want a new one i just want this one to work
Yes, I understand. Hope I didn't come off like some condescending American, like I have a money tree in the back. However suggest you fix it right, or do not use at all, or soon it will be permantely damaged. The main thing you need is that Charger Board. It has the DC Power Jack mounted to it. After removing the System Board (Motherboard), and unplugging the cable to the Charger Board; remove two Philips head screws; remove the Charger Board. Place a large metal object on the table you're working on, and frequently touch it when working on the laptop, if obtaining an ESD wrist strap is not feasible for you. I can step by step you through in replacing, but you need a replacement Charger Board. Maybe one of these sellers ships to Jamaica,http://www.ebay.com/sch/i.html?_odkw=&_o... $14.39 in USD is $1373.46 in JMD.http://coinmill.com/JMD_calculator.html#... http://www.amazon.com/s?ie=UTF8&page=1&r... (My goal is to help you)
SOURCE: laptop won't turn on
I am facing a similar problem with 5160 and my power button will not power up the laptop. I presses the shift key, it got powered up (offcourse only fan started but the screen is black)
Try pressing shift key to power up.
The blinking orange battery light generally indicates that the battery isn't working properly, usually going out and not charging properly. In this case, since the adapter will not power the machine without the battery, and it should, I'm going to say that the adapter is going out and not getting the proper amount of power to the system. Try replacing the adapter. Be sure to replace it with a Dell replacement, the Targus brand universal adapters do not work well with Dell machines, and in most cases won't work at all.
SOURCE: My Dell Laptop is not turning on
Possibley it could be some internal parts. Please try run the onboard diagnostics by holding down Fn and the power button. Make a note of the 3 lights above the keyboard (9,A and the lock key). If it starts for a second and then shut's down, the MoBo will ahve to be replaced. 1501 has known issue and I know this as I work for DELL tech support. Call tech support or chat with them...If the product is under warranty, you should get a replacement.
Pardon my spelling mistakes!!! Let me know if the information was useful or not.
SOURCE: Laptop does not work with AC adaptor, does not charge. Mother board issue
You may be able to get a battery charger but its rare.
If you do wish to use the AC adapter, take care with positive and negative. Also the voltage of the battery is actually lower than the AC adapter in order to get charged. I don't know what is going to happen if you do choose to use AC adapter as battery. 75% chance that it will work.
SOURCE: dell inspiron 1521 won't turn on!
Try this: remove the battery and unplug the power, hold down the power button for 10 seconds, then plug the power back in, and try turn it on again. If this doesn't work, check the power plugin port, if anything in there is moving around, it might be broken and need to be repaired. Check for a local electronics or computer store for that. The only other problem I can think of is that the motherboard died, probably from over-heating. This usually requires a new laptop, or an equivalent price for a new motherboard. Good luck, I truly hope the first one works.
