SOURCE: wine cooler doesn't cool properly
Few things to check here. If the compressor is not running then the problem may be a bad thermostat or the compressor start device (ptc starter). Most common would be the thermostat on wine coolers. Also need to check if the fan is running. If everything is running then you have a sealed system problem. If the fan is the only thing that is not running that will cause a no cool situation.
SOURCE: Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
SOURCE: haier wine cooler
Thanks, I set the temp higher and I'm waiting to see if it actually goes up or keeps getting colder . I have notice that the red light that was lighted before is out and now the green light is on . Not sure what that means but usually green lights are better that Red !!!
SOURCE: Making clicking sound motor gets hot but not cooling
Your PTC relay on the compressor is bad needs to be replaced.
First be sure to unplug cooler. Remove the cardboard cover that covers
most backs of the units. Remove the plastic cover that is on the
side of compressor. It is held on with a metal clip. Now you should be
able to see the relay pry the relay straight off. note the wiring and
position of relay. Only three prongs on compressor. Go to a parts house
for appliance's and with your make and model number should be able to
get a new one. Let me know if you need any more help. ken
SOURCE: Everstar Beverage/Wine Cooler HDBC36ID not cooling
I returned our unit to Home Depot with relative ease... I think they were all aware there is a problem with these units.
They refunded the full purchase price (even though I was well past the 12-month warranty period). I put the money toward a GE Profile unit that's a little bigger - more expensive, yes; but it works, priceless!
