SOURCE: change nat type from strick to open
1)NAT STRICT
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox
Step 7: Get the IP Address of the Xbox
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
Goto : my blog for more information about belkin routers (Page is still under construction )
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
To reduce the NAT
1 ) Disable the firewall in the router
2)
Enable the Playstation in the DMZ
3) Make sure UPnP is Enabled
SOURCE: trying to hook yp wireless router, device will not
device will not get al the way in to it .....
What do you mean ?
SOURCE: How can I changes my
By default the IP address should be set to 192.168.1.254, insert this in the browser.
You should see a box prompting you for your username and password. Enter your username and password now. By default both the username and password are admin. Click the Ok button to log in to your router.
Click the Virtual Server link near the left of the page.You should now see a new menu. In this new menu, click PPPoE/DHCP/Static.
PSN requires you to forward the following ports:TCP: 80, 443, 5223
UDP: 5223, 3478, 3479, 3658
Go ahead and enter the settings shown above into thePPPoE/DHCP/Static Configuration menu.
When you're finished, click Submit near the bottom of the screen to save your changes.
And that's it! You're done!
