How can I change my NAT type from NAT 3 to NAT 2 for my PS3.
SOURCE: How do i change my router's nat type 3 to nat type
Instead of changing the NAT type, it is effective to forward ports on the router for your PS3. Perform the steps as mentioned in the below link:
http://www.portforward.com/english/routers/port_forwarding/Netgear/WPN824/PlayStation_Network.htm
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
SOURCE: ps3 nat type 3
In order to achieve NAT 2, you are going to have to set your PS3 to a static IP address and forward ports on your router.
detailed instructions on how to do this and configure your ps3 can be found here:
http://www.pregamelobby.com/forum/sony-reviews-tips/5618-how-get-type-2-open-nat-your-ps3.html
In order to get into your router settings, go to 192.168.0.1 OR www.routerlogin.net (the router sets up its own DNS) and putting in your username and password. If you have not set up a password, the default username and password for this router is "admin"/"password". Follow the instructions in the page I posted once you are logged into the router's webmin.
Hope this helps!
SOURCE: I have a Zyxel P-660r-d1 modem and I connect to it
i will repost my guide for opening nat and firewall on a zyxel ...
it will help for sure ...
you can't just say nat is now OPEN :)
let's say you have a pc with IP of 192.168.1.33
you are running a emule (hehe) on that PC
you want to use port 12345 for your emule
this is what you need to do:
1. go to webinterface of your router (usually http://192.168.1.1)
2. go to menu network/nat/port forwarding
3.go to service->user define
4. in new window click "active", name it emule, start port 12345, end port 12345, server ip 192.168.1.33
5. click ok, apply, whatever and go to menu security/firewall/rules
6. choose packet direction wan to wan/router
7. click on ADD
8.change following fields: destination address - change to single addressand change 0.0.0.0 to 192.168.1.33 and click on add, then close to itsays ANY, mark it and click on remove
9. on same page under services click on edit customized services
10. choose number 1 or 5 or whatever :)
11. service name: emule rule, service type TCP/UDP, type single, port 12345
12. click on apply
13. go to menu maintenance/tools/restart
14.just in case restart the box and your zyxel is now accepting incomingconnections on port 12345 and forwarding them to 192.168.1.33 (your pc)...
i hope i helped
cheers
-tomba
SOURCE: nat type changes back on ps3
you need to make sure that when you change it that you apply in your modem setup page that bridge mode is activated so that it turns it into a dumb unit allowing just to pass through the internet stream thus allowing constant nat 2 connection
