Health & Beauty Logo
jim miani Posted on Feb 01, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have a amigo smart shopper scooter and "dead man" switch apparently not working correctly. When I depress thottle, scooter goes forward without any weight on seat?
Cliff J
Level 2:
Scholar:
New Friend:
  • Expert 90 Answers
  • Posted on Apr 22, 2015
Cliff J
Expert
Level 2:
Scholar:
New Friend:
Answers
90
Questions
0
Helped
46835
Points
123
Have you had it for some time or did you just get it. If it was working and now it is not, you most likely need a new switch. If you just got it, it is possible that the previous owner bypassed the switch. Look under the seat and see if the wires are connected to the switch. If they are not connected, connect them to the switch. If they are connected, you need a new switch.
newsleet
Level 1:
New Friend:
  • Contributor 53 Answers
  • Posted on Nov 01, 2013
newsleet
Contributor
Level 1:
New Friend:
Answers
53
Questions
0
Helped
15534
Points
58
Need to know how old unit is smart shoppers now use seat switches that are normally open without weight and when seated normally closed, if you unplug the wires that come from the seat switch and the cart doesn't move then the seat switch is stuck and should be replaced. older units were normally closed without weight and normally open when seated in this case check to see if the wires have come unplugged and reconnect them then recheck if cart won't run when seated replace seat switch.
1 Related Answer
Anonymous
  • Posted on Jul 13, 2010
SOURCE: amigo smart shopper
FIX IT
MAY IT NEED CERTAIN PARTS
My amigo smart shopper goes fine for a few seconds then stops and beeps
please use your manual to diagnose the cause of the beeping issue and the corresponding solution. If you don't have a copy, please call the manufacturer at 800-248-9131 . Thank you.
How do you add a throttle control POT to an amigo value shopper? I see where it goes on the circuit board but need to know the value and the pin out. Thanks in advance.
older smart shoppers had a speed pot built onto the throttle assy. but the value shopper is programed into the motor controller user can't change
I need a manual for the amigo smart shopper cart
You will need a serial number, should be at the bottom of the steering shaft or in the battery compartment, call amigo at 1-800- myamigo for help when you have it
How much does a new amigo value shopper scooter cost
Grainger has them for $2630 new. There are used ones on ebay for $350
Controls won't respond
Does the battery indicator light up. If it does then remove the rubber seat cover to expose the seat safety switch then turn power on hold seat switch down and try the throttle if the cart moves then try to put 2 10 x 10 pieces of card board on top of the foam directly above the seat switch then put the rubber cover back on.If it doesn't then have the on off switch and batteries checked or contact amigo for the nearest service company in your area (1-800-my-amigo)
Have an Amigo RD. It goes reverse perfectly, but it stalls going forward. Help?
My Amigo RD was doing the same thing, I had to replaced to circuit board and that fixed the problem, don't replace the pot throttle, because I replace the throttle thinking that was the problem, but it wasn't. It was the circuit board.
I want to reprogram an Amigo Value Shopper to have a faster top speed
Sorry but you would need a programmer to attach to the controller I am a service tech and use it to program the controllers
I snapped the cable on my amigo value shopper what do i do
if it's the wire that drags on the ground it's a static ground, you can order a replacement from amigo or make one from a piece of stranded copper wire (14 gauge)
strip 3 inches of insulation then wrap once around axle and twist together cover twisted portion with electrical tape to hold together make long enough to allow end to drag on ground
strip 1 inch of insulation to allow wire to contact the ground and that's it
it it's the gray flat cable or the motor wire it will need to be replaced
Where are settings on amigo smart shopper
In the motor controller and depending on the age may or may not be adjustable without a programmer
2answers
Top Amigo Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Amigo Health and Beauty Expert? Answer questions, earn points and help others
