20 Most Recent
Amigo RD 3-Wheel Scooter w/33AH Batteries - Color Cinnamon Red - Deluxe Pac Questions & Answers
Seat will not raise. push 'up' button
could be one of several problems, if it goes down then it could be the keypad, if nothing then wiring, motor, or controller. Best to have a trained tech to check out.
Seat removal
should be a nut and bolt or possibly a pin in then seat post remove and lift seat out
Scooter charges but doesnt run
could be one of many problems is the battery indicator blinking on the control box if so check on/off switchcheck seat switchfree wheel switch located in the slot on the back right side of the battery cover check for proper positionalso there are 2 small lights just to the lower left and lower right of the battery indicator that will blink a error code examples are 1blink pause 2 blinks or 2 blinks pause 2 blinks and many others if you have the error codes contact amigo for a help 1-800-my-amigo
I have an amigo RT,
check the charger, if you plug it in the indicator should blink for aprox. 30 sec. then go solid and when charge is complete the indicator will start to blink again, also if the charger is working the scooter should not move when plugged in, if charger not working check power cord before replacing charger
