When the antenna winds all the way up grab it and try and pull it up as far as you can get a bit of oil/grease or lubricant and run it along the antenna to help it run smoothly, this wont fix your problem but it will reduce the amount of clicks it does and may help realign the antenna as the clicks are the motor still trying to pull it down because it thinks its still up. the antennas do this because they may have a kink or bend in it, most cases you need to replace the antenna, can get one for under $50 get a generic one as its cheaper and does the same thing.
