2002 Nissan Xterra Logo
Posted on Jan 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Radio not working
I have a 2004 xterra radio will not work. Checked all fuses they are all good still cannot get radio to come on. clock on radio stays on constantly at 12:00 please give advise on this problem.
  • brianew1977 Jan 22, 2009
    i'm trying to install a dvd player in my truck, any help figuring out the wiring would be greatly appreciated
Steve Allison
Level 3:
  • Nissan Master 5,569 Answers
  • Posted on Jan 11, 2009
Steve Allison
Nissan Master
Level 3:
Answers
5569
Questions
Helped
2002636
Points
16452
There are two lines that supply +12 to a radio; one is active when the radio is turned on, the other is active all the time and this is the line that keeps the clock running and your selected stations from being lost when the key gets turned off.
If this is an after-market radio, the fuse is likely to be under the dashboard, in series with the line that is used for primary power when the radio is in use and is not making it all the way to the radio.
Anonymous
Level 2:
Scholar:
  • Expert 89 Answers
Anonymous
Expert
Level 2:
Scholar:
Answers
89
Questions
0
Helped
60176
Points
250
If you have recently changed the battery or lost power for any reason your radio may require an anti theft code, check your manual to see if this even applies to your vehicle. You may be able to find code behind the glove box in some cases. Or look up your vehicle online to see if any codes are posted. If the clock is working you have power.
3answers
Why would my 2003 Nissan Xterra A/C blower and radio lose power 2 days ago?
Question edited for clarity.
Question moved to model category.
There are three fuses and a relay that cover the blower. Radio probably has an inline fuse, but they are also monitored by the Body control Module.
Nissan Xterra (WD22; 1999-2004) fuses and relays
https://fuse-box.info > nissan > nissan-xterra-wd22-199...
Fuse box diagram - Here you will find fuse box diagrams of Nissan Xterra 1999, 2000, 2001, 2002, 2003 and 2004, get information about the location of the ...
2answers
What is the fuse number 23 control on 2004 Xterra
The fuse location and control function are listed on the inside of the fuse box cover or panel.
Radio lites up but no sound
Should be a memory fuse which powers the clock, and a radio fuse for the actual receiver.
Have you checked both fuses ?
1helpful
I have a 2004 Saturn. The radio, cd and clock display just stopped working one day. Checked the fuses. How do I fix this?
If it is a detachable face,make sure the face is on good. If not and you checked the fuses,then you need to check the wireing to the radio. FYI these late model cars have fuses under the hood as well as inside the car.
1helpful
Does 2006 xterra have speaker fuses
no it will not its part of the radio only . Speakers only work if good and the radio must work also. Checked your radio fuse?
2004 corolla cigarette lighter, radio, and clock
You may have a short in the dash, i would have it checked by a mechanic, if it is a short it could cause a fire, so you should have it checked ASAP........
2helpful
2004 Nissan Xterra. Battery died and now the radio will not turn
Hi, check the fuse box for a blown fuse in the radio slot. sometimes during jumps, this fuse will blow.
1996 dodge dakota radio and clock don't work but the fuse is good
bad radio i have seen it before have radio or change radio might chrck before you change and be sure the wires are pluged in good
6helpful
Clock on the console is not working.Checked the fuse says its ok.
If the fuse is OK then it is the clock itself. I offer an affordable repair service, check out
www.autoclockrepair.com
2003 Xterra radio power dead
trace the wire back to the fuse box with a lighted 12V tester and if the fuse appears to be good, check the hot side of the fuse and go from their. You might have to find another hot point (key activated) to wire the stereo into with an inline fuse.
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Nissan Expert? Answer questions, earn points and help others
