If you are shooting to right do you turn scope left
SOURCE: Hello, I have a Bushnell sportsman 3x9 mounted on
Start buy loosening the scope in the mounts. Loosen the front first to see if it is in a bind (left/right). Tighten it back down but not completely. Loosen the rear looking for some movement or popping sound. If you see a movement or notice some odd thing. check the mounting slots for dirt or dings that may cause an offset to the mount. If all is well. Go and start and zero for 13 - 15 yards. you want to be 1 1/2 inch hi. Now after each shot rap the scope with a screw driver handle or something solid, just to give the scope a shock not hard enough to bend it or dent it but shock it. Large scopes are meant for larger shock than a 22 produces, rapping the scope will help move the cross hairs and settle them in place. Hope this Fixya up. If it does help, please leave a testimonial. Thank you for using Fixya.
SOURCE: how do I adjust my scope? it shoots 1/2 inch left
Turn it to clicks left and give it anoyher try!
SOURCE: My Bushnell Banner rifle scope
you might be able to buy a weaver rail adapter that can change your elevation aswell as lift up your scope a bit just to make it a bit easier to see out of. try something like this maybe http://ant-supplies.co.uk/DovetailtoWeaverAdapters.aspx
