Music Logo
calebjean Posted on Oct 24, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a korg keyboard I need to replace a key
Thomas Perkins
Level 3:
  • Master 15,088 Answers
  • Posted on Oct 24, 2012
Thomas Perkins
Master
Level 3:
Answers
15088
Questions
0
Helped
3389864
Points
54869
I need a fuse for a Korg N364 keyboard.
No one knows the fuse type, but the details should be on the fuse itself. Then you can't get them from an electronics store or Amazon.
The Service Manual is in the link.
https://www.google.com/search?q=Korg+n364+keyboard+replacement+fuse
Apr 12, 2024 • Korg Music
How do I restore a dead key on a Korg X5?
What do you mean by applied graphite...graphite powder? That is not the solution I wouldn't think, you need to use a keyboard contact repair kit, which has a solution you paint on? Something like the link provided might be in order. Make sure there are no improper conductive bridges formed between the contacts in the PCB board surfaces. Replacement rubber pads (the part that presses down) are available from any decent service provider (try Syntaur if can't find http://syntaur.com/korg_x.html ) (beneath key) Korg Key Contact Repair Kit Replacement Keys and Parts for Korg Series Keyboards
Jan 14, 2015 • Korg Music
Some keys wont work after my korg pa50sd is turned on
It's about hardwares.
If dead keys are the same notes(C2-C3-C4 or E2-E3-E5 etc),its electronic parts problem.
If dead keys are random(D1-F1-G3-B5 etc),chances are :
  • Rubber keypads is break. Below the keyboard. Replace it.
  • Dust can cause bad contact the carbon inside the rubber keypad. Clean it.
Korg pa800 256mb styles set
I wouldn't recommend doing that, because your OS system could freeze occasionally
Some keys on the left side are not giving sound when played and the master volume is loosing can it be fixed or should i have to buy a new master volume
Wiring connection sockets is loose.
Inside the korg PA50,Wiring connection to the keyboard is separate to left and right.
Open/disassemble your korg.
Look for connection cable to the left keyboard.
One end is on the keyboard,the other end is at the mainboard.
Unplug both of it, then mounted again.
For master volume,better buy new one.
Korg m50 freezes after 10minutes
Hello I have this M50 61 key korg model, I had the same issue the fix is simple remove the back cover on the unit, carefully push in all the small cables reattach them well do it to all the small connectors these cables get lose and cause this issue, good luck let me know if that helped I fixed mines that way its been working excellent since. good luck..
Korg M 50
Korg Support advises that they can either provide you end cap or direct you to a retailer. CLICK HERE
1helpful
Need to replace black keys on Korg triton. Is it a major job to take the keyboard apart and replace the keys? In Bermuda there is very limited repair resources. I have replaced keys before on my old...
Typically lots of screws to remove. Be careful unplugging any ribbon cables. The cables are easily damamged by exerting force on just the edges.
Have new parts available BEFORE taking it apart for repair.
Oct 02, 2009 • Korg Music
Top Music Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Music Expert? Answer questions, earn points and help others
