20 Most Recent Korg Pa50 Professional Arranger Keyboard with SD Card Slot Questions & Answers
i use korgpa50sd i had some voices by default but once when i inserted my sd card into the arranger every voices got deleted and now everything is new...so can you please help me to get back the old voices?
Korg Pa50... | Answered on Apr 30, 2016
It is power supply regulator problem.
In the regulator circuit, DC 12volt from adapter is separated into +8V, -8V, +5VA, +5VD. Some causes when the unit hang /blank/ frozen is one of the existing supply voltage is drop. In general, +5V.
Also check the adapter voltage, if still normal and the current is sufficient.
Adapter must have DC12volt and current of at least 3 amperes.
It may happen, when the adapter is measured without load, it's read normal 12v, but when loaded to turn on the keyboard, many voltage decreases (lets say,between 8-10v).
This indicates that the adapter is not good and need to replace.
Korg Pa50... | Answered on Sep 01, 2015
Floppy emulator can't read flashdisk untill it formatted.
Flashdisk MUST BE format by special softwares.
Install the softwares on the PC/notebook.
No matter how much flashdisk capacity,floppy emulator will continue to read as one 1.44MB floppy.
Through special softwares formater, we can determine how many floppy that we will create. Lets say,100 floppy (or more),softwares will format the floppy 1.44 100 times on the flashdisk.
So we have 100 pieces 1.44MB floppy inside flashdisk. If one floppy can store about 30 MIDI songs,then it means that we already have 3000 songs in flashdisk.
If you format for 100 floppy,the total capacity of about 144MB.
So,flashdisk with a 2GB capacity, is more than enough to store songs.
To change from one floppy to enother,just press bank number at floppy emulator panel.
I hope this helps.
Regards.
It's about hardwares.
Wiring connection sockets is loose.
Inside the korg PA50,Wiring connection to the keyboard is separate to left and right.
Open/disassemble your korg.
Look for connection cable to the left keyboard.
One end is on the keyboard,the other end is at the mainboard.
Unplug both of it, then mounted again.
For master volume,better buy new one.
Your questions,what does it mean?
If you use PA50SD,of course you don't need floppy emulator.
If you use PA50 with floppy emulator,you need to format the flashdisk with special softwares (SFD 1.23 etc) that usually included when you buy the emulator.
If dead keys are the same notes(C2-C3-C4 or E2-E3-E5 etc),its electronic parts problem.
If dead keys are random(D1-F1-G3-B5 etc),chances are :
  • Rubber keypads is break. Below the keyboard. Replace it.
  • Dust can cause bad contact the carbon inside the rubber keypad. Clean it.
The manual should the factory re-initialization procedure. If not contact Korg customer support
If the problem still exists after trying multiple cables and speakers then the problem is either the jack itself or the amplifier in the unit. This should easily be fixed by an authorized service center.
The PB sensitivity may be turned off for all the track(upp1,upp2,upp3,lowr).Turn this on to desired level.Also check the joystick settings.Turn that also on.PB sen and joystick options are there in menu.
Korg Pa50... | Answered on Jan 02, 2015
Your keyboard has a factory defect. Return it to the store or manufacturer and let them give you a new one.
If you waited to long and your warranty has expired take it to a repair shop. There is nothing else you can do...
Korg Pa50... | Answered on Jun 13, 2014
ola claudio
tienes que resetear el organo y despues cargar el os
Korg Pa50... | Answered on Jan 21, 2014
Here is a link to your manual, it should tell you how to do a factory reset somewhere in it. Hope this helps.
http://www.korg.com/uploads/Support/Pa50SD-UM-ENG_634618903911880000.pdf
Korg Pa50... | Answered on Dec 03, 2013
para resetear el pa50sd
Please see "Loading Korg Pa50SD's Operating System" below for
instructions on how to load the operating system.
Korg Pa50... | Answered on Oct 26, 2013
*** fac o resetare generala la pa 50 sd
Korg Pa50... | Answered on Nov 12, 2012
Korg Pa50 Professional Arranger Keyboard with SD Card Slot Logo
33 questions posted
Top Korg Music Experts
Vernon Taylor
Robert Graf
David Gust
Are you a Korg Music Expert? Answer questions, earn points and help others
View Most Popular
Korg Music
  • Korg Music
Most Popular Question
reset pa 50
  • Music
