Wiring diagramme
SOURCE: brake light wiring diagram 1972 Gremlin
I have a 72 amx, the two wire conector at the brake light switch down on the brake pedal is light green and pink and the plastic connector is brown and plugs into the switch at the top of the brake pedal.
SOURCE: need diagramm on how to
Hi there. You dont want to tap into any wiring harness'. Your best bet is to run a hot wire from the battery or the fuse box to a switch then to the lights. If you wire it to the fuse box/ panel you will want to use a spade connector. It looks like a **** connector but one end looks like a flat square shovel. Make sure that you run a fuse somewhere between the power source and the switch.
Happy wiring!
SOURCE: How do u wire I'n a 1972 ford f100custom truck
Sorry iam a thick brit having problems with your spelling which as we all know we cannot spell in the UK or pronounce aluminium or tomatoes so the man to ask is emmisionwiz as hes a ford dealer fitter with enough years under his belt to know exactly what you need to know ,so try a direct question ,but for this year with a seperate regulator why not try a alternator off a later model with a built in regulator ,as for the starter motor then a wire from the contact switch on the back of the key switch that has power when the key is turned to the start position and this wire goes to the small terminal on the starter motor .I do not the facility of a fancy pen thing attached to my computer that i can draw a quick pic for you .
SOURCE: I need wiring diagramm to hook scheppach 4010 to 380v
Fixya.com has no file of wiring diagrams. Sorry
