I need a instructions manual for XO Vision Mhd4710i Car Video Player
SOURCE: XO Vision XOD1740BT in dash dvd player bypass code
I solved it By connecting the pink wire to a constant ground this acts as a bypass so the unit plays anytime.
SOURCE: everytime i take turn the car on or off the radio resets to defau
If you are losing the memory (clock and presets) on the unit, you need to make sure that the yellow wire (normally) has 12 volts AL THE TIME and the red (acc) is switched on and off with the key. The battery wire (memory consant 2 volts) is the one that retains memory.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
SOURCE: xo vision dvd player
hi there
it shouldn't be to hard to install this but it does require cutting a hole in your interior part of roof........a install like this could take anywhere from 30 mins - 1hr for a installer to put it in. to do it yourself it could take 1-3hrs to complete (note for your first time doing this take your time and follow the install manual that will be provided)
SOURCE: no owners manual in box when I bought the XO Vision 1736
It does not look like the manufacturer provides a download link to the manual. I would suggest either calling them or emailing their support and requesting a copy be sent to you. Their contact info can be found by clicking the below link.
http://www.xovision.com/contactus.php
