20 Most Recent XO Vision XO9013 Car DVD Player Questions & Answers
hi! there might be some technical problem in concern with the connection or wiring of your speaker. or maybe battery is not that strong enough to give full blast to the four speakers.
XO Vision XO9013... • Answered on Sep 17, 2016
the aux output is for an mp3 player or ipod. Does the HU have preamp outputs? The RCAs from the amp should go into them. If it doesn't you might have to get a high to low level input converter
XO Vision XO9013... • Answered on Nov 21, 2015
How i can change lanague japenes to english of poinor avc drz80
XO Vision XO9013... • Answered on Mar 01, 2014
yea it will work if u leave the car running but once u shut off the car and turn it back on it doesnt work there has to be another way
XO Vision XO9013... • Answered on Feb 06, 2014
this wire is the gray wire with the round eyelet. go to a metal ground and the Video will play
XO Vision XO9013... • Answered on Oct 07, 2012
Check the wires on the back of unit and make sure BOTH ground wires are connected. If the secondary ground wire isn't connected, the screen will not display video var viewReq = new Array();function vu(u) {var i=new Image();i.src=u.replace("&","&");viewReq.push(i);} vu("http://googleads.g.doubleclick.net/pagead/adview?ai\x3dB5oiTuDkeTabZAYz2lQei4_zcDcCshNABsIqYug3kveKqGAAQARgBIAA4AVCAx-HEBGDJ1pqLwKTYD4IBF2NhLXB1Yi0zMzg0OTQ2Mjg1MzUxOTU2oAGM97n0A7IBDXd3dy5maXh5YS5jb226AQozMDB4MjUwX2FzyAEJ2gEzaHR0cDovL3d3dy5maXh5YS5jb20vc3VwcG9ydC90NzA2MzUwMy1zbV8zMTB0X3N1bWFzmAKqGsACBMgC7JPpCeACAOoCHjYxNTMvZml4LmVsZWN0cm9uaWNzL2Nhcl9hdWRpb6gDAegDpQnoA-YB6APsA-gDBfUDAAAABOAEAQ\x26sigh\x3dUP1Q3dP6C9g") body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(/wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; }
XO Vision XO9013... • Answered on Oct 07, 2011
try audivox.com. audiovox owns jensen.
XO Vision XO9013... • Answered on Feb 24, 2011
its no fleje, its flex in english or spanish , its the flex ribbon connect the circuit with the screen, i hope this help, suerte.
XO Vision XO9013... • Answered on Oct 08, 2010
  • 1st you will need to purchase a 12 volt or above Momentary Push Button/(Toggle)switch (about $5 Radio Shack)
  • 2 2nd Using the Diagonal Pliers adjust the length of the Radio's Emergency Brake Wire to your desire. Make sure you have enough wire so you can mount it where you can easily access it like beneath your steering wheel/ on the Dash Board.
  • 3 3rd Connect one end to the emergency brake wire from the radio and then connect the other wire from the switch to a ground to your car. You can use the same ground connection that you used for the radio and it will be fine. Make sure you wrap up the wires using the Electrical Tape to prevent shorts.
  • 4 4th (Using Button Switch) When you are ready to use the DVD player insert DVD and after a few seconds the screen will turn blue and the message to "Set the emergency brake" will come on. Now just press the button (4x Times)for one second and release it. On The fourth time the screen takes about 6 second to display the video.
  • 5 5th (Using Toggle Switch) When you are ready to use the DVD player insert DVD and after a few seconds the screen will turn blue and the message to "Set the emergency brake" will come on. Now just flip the swtich on and off (4x Times). On The fourth time the screen takes about 6 second to display the video.
  • 6 Now your Passengers can enjoy the ride & Movie!!
  • XO Vision XO9013... • Answered on Sep 29, 2010
    how long have you been using the player? And has it been giving you this type of problem before now?
    I think the fault is from the laser (lens) of your player. The lens is very weak such that it cannot read the data or files on a disc, that's why it should disc error, even though it plays some disc but that doesn't mean its not a lens problem.
    You need to look for a way to replace the lens for your player so that it can play all discs perfectly well again.
    Good luck.
    XO Vision XO9013... • Answered on Sep 25, 2010
    Most wiring harnesses have a solid orage wire for illumination of the radio and also have an orange wire with a white stripe for dimming purposes. Most radios do not use this dimming feature. Connect the brake wire to this wire and your able to watch your movies whenever you want. All the wire is looking for is a signal. It cannot differentiate between a parking brake signal and a non-parking brake signal.
    XO Vision XO9013... • Answered on Aug 17, 2010
    There is NO CODE, this is a wired in function, usually to the Brake Pedal, or hand brake, ONLY when they are activated, ie: In Use, can one watch the screen. Or when the Car is ignition turned off.
    XO Vision XO9013... • Answered on Apr 01, 2010
    hi, i bought eonon E1012 on Eonon official, i also changed the wire so as to watch car DVD, but everything turn out to be fine.
    I think maybe you have connect the wrong wire and have bum out the built in amp.
    XO Vision XO9013... • Answered on Mar 06, 2010
    Look at the rear of the player, the plug receptacle has a color ring, that should match the color of the RCA plug.
    If that not the case, the two stereo audio plugs should be similar in shape and color, and placed side by side on the player, while the video one is just one plug, placed well apart from the other two.
    XO Vision XO9013... • Answered on Dec 04, 2009
    XO Vision XO9013 Car DVD Player Logo
    Popular Tags
    39 questions posted
    Top XO Vision Car Audio & Video Experts
    ADMIN Canada
    ADMIN Canada
    ray gallant
    Relax
    Relax
    Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
    View Most Popular
    • XO Vision Car Audio & Video
    Most Popular Question
    sm 310t sumas
    • Car Audio & Video
