When I turn the monocular on the inside flashes as if someone were taking pictures with a flash and I were looking directly at them. I have changed the triple A batteries and still have the same problem.
SOURCE: manual and what generation
Hey there candotha, the site found here:
http://www.amazon.com/Night-Owl-Cyclops-Vision-Scope/dp/B00004THMR
has some reviews which will be of use to you. I hope it helps. The manuals seem quite hard to locate, but I will notify you if I have any luck.
SOURCE: battery replacement for Night Owl Night vision monocular
just press down and away from the lens, on the ribbed square located on the spine of the monocle
SOURCE: Dysfunctional Night Vision
dont power this up in full day light or you will burn out the ccd pick up if you cant see anything through it i gess the tude has burnt out
its common for this to happen there life span is only about 1000 hours and much less if exposed to bright light, ie minuets!
Testimonial: "Thank you. "
SOURCE: Night owl nocc3 looks like a star field inside
it sounds like the light "pickup" at the front is not working,, was it stored with the front lens cap fitted and in the dark? if not you may have bamaged this "pickup" it could also just be dirt on it,,you can undo the front lens and clean the "pickup" if the unit is turned off and you use a soft lint free cloth
SOURCE: I don't know how to
Hello Here Night Owl Optics owner manual web site for your monocular: http://www.nightowloptics.com/documents/NexGenMonoMULTImanual.pdf
One more thing. DO NOT LOOK THROUGH NV
MONOCULAR DURING THE DAY, OR LOOK AT BRIGHT LIGHTS. This
will destroy the image intensifier tube. Bright lights will make it go south
faster than Speedy Roadrunner. I need parts if the image tube is gone. Night Owl
Optics in El Paso, TX will charge you about $200 plus parts and shipping to
repair it. So, listen no looky at bright lights in the neighbor bedroom window,
hey. GB...stewbison
