Is my ASRock CONROE1333-DVI/H R2 mobo compatible with this cpu: Intel Pentium D 830 3000 MHz Socket 775 desktop CPU SL8CN, 2M/800, 64-bit, Smithfield dual core
Http://www.asrock.com/mb/overview.asp?Model=CONROE1333-DVI/H
CPU Support List,
http://www.asrock.com/mb/overview.asp?cat=CPU&Model=ConRoe1333-DVI/H
Intel Pentium D model 830, Smithfield Core, sSpec Number SL8CN,
http://www.cpu-world.com/sspec/SL/SL8CN.html
From all indications -> YES
Regards,
joecoolvette
[-> FOLLOW Anti-Static Precautions. A Processor is the most susceptible hardware component to Static shock.
Use good Thermal Paste,
http://www.hardwaresecrets.com/article/274
Testimonial: "thx joe and every one els who helped :) u guys are a big help i will try it and see what happens XD"
SOURCE: asrock P4i65G motherboard/CPU
Hi Rlforeard, yes the BX80546PG3000E is compatible with the motherboard P4I65G.
http://www.alvio.com/product_view.aspx?product_ID=61048&source_ID=froogle
Here is the list from Asrock. CPU's supported for the Asrock P4I65G board. You will find you can go higher.
http://www.asrock.com/mb/cpu.asp?Model=P4I65G&s=478
Good Luck!
Mike
SOURCE: CPU Compatable
I bought my last computer at Cheap Guys Computers and it included the SG-80 with the Pentium 4 already installed and after two years, the only problem we've had with it is a damaged HDD from my wife dropping the tower while it was running. My suggestion-Do it!
SOURCE: Will this CPU be compatible with this MOBO?
Okay your Processor is not supported by your System Board. I will take some time and look to see what would be a good upgrade, but it may take a few days.
Ryan Frame
Creative Energy Associates Technical Center
SOURCE: i am building a brand
http://www.intel.com/p/en_US/support?iid=hdr+support
This is an Intel link and, down the page a little, there is a compatabilty option you can pick. This will answer your compatabilty question. You can also enter your info in the browse for product support .
SOURCE: hello, i got maximus formula
This is your board by the numbers you supplied:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131199
You have Via P4M900 and VT8237 chipsets and Realtek ALC662(sound)
This is Asus's link for your board:
http://www.asus.com/Motherboards/Intel_Socket_775/P5VD2VM_SE/#download
It's supported to Windows Vista so, it may or may not work with Windows 7.
You can try your sound here, if necessary:
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=24&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false
and, this is Via's link:
http://www.via.com.tw/en/support/drivers.jsp
It appears your board has the support for Windows 7, if that is what you are running so these should be all you need. Let me know if I can help you further.
Dave
