WHAT IS SOLUTION OF NON COOLING A.C. AFTER STARTING OPERATION AND TIMER LIGHT START BLINKING
SOURCE: HI, I have a Fujitsu ASTA18lCC. Fan working but
trying to get the compressor to operate. it could be a bad capacitor and the compressore wont start or maybe the compressor is burned up
Testimonial: "Thanks for the advice. It turned out that we had a blackout after the AC had started playing up. The blackout seems to have sorted out the problem.Thx"
SOURCE: friedrich m18cf have timer blinking
If I see a code blinking and all is normal as far as I can tell it means something is in a time out mode and counting down to energize. This may not be the case but let it run and blink for a few hours and see if it comes on.
Mark your watch so you can see how long it takes to change or start.
If it does start then you know about how long it will take to recycle.
Assuming you have changed the batteries in the remote (if you have such), and it does this again do not use the remote again, if possible. Try it with manual only. Remote - remove batteries, this will eliminate the remote as the cause.
Next is find the legend of the codes for your unit. Sometimes they are located by the wire diagram on the unit its self, under the wire terminal panel.
If this helps you please rate me as high as possible. If it gets you on the track and need more help tell me what you did and what you found, post it and I'll post back asap.
Thanks for using fixya. and Good Luck.
SOURCE: problem with RAS-30CS5
the system may not have any refrigerant in it, this may be a safty cut out. hope this helps
SOURCE: Fujitsu Heat Pump - problems
I had the same problem. The heater did not work in heating mode. However it was OK in air-conditioning mode. The operation light and the timer light blink twice and then the operation light blinks for 5 times followed by few seconds non blinking, then the cycle repeats again. I have read on the internet that you better unplug the power cord and then plug it again so that the heater re-sets itself. My only problem was that my heater is directly plugged to the power with no visible plug. So I went to the main distribution board and put off the power for about 20 seconds for the whole home. HOORAY!! The heater worked after that.
SOURCE: indoor unit runs ok outdoor unit compressor and fan do not start
Hello rfrizzell,
My unit is giving me the same alarm. If you have found the solution, please email me at [email protected]
Thank you very much.
None TV is powered off. Normal operation.
Green TV is powered on. Normal operation.
Green 1. TV just plugged into AC outlet.
Wait until blinking stops before turning on (approximately 1
minute). Normal operation.
2. AC just restored after power failure.
3. TV Rebooting after System Reset was
used.
4. TV Rebooting after power fluctuation
or receiving abnormal digital signals
from digital channel, or digital device.
5. You have begun the procedure to
update software from an authorized
flash memory device.
For detailed information, see the instructions that accompany
the authorized software update. IMPORTANT: Do not
use unauthorized software at any time.
Green TV just powered off and lamp is
cooling.
Starts to blink 30 seconds after turning off TV. TV can be turned
on before blinking starts or after blinking stops, but not while the
indicator is blinking. Normal operation. hope it helps regards shaun
Green TV powered off and auto-on timer is set. Normal operation. TV can be turned on at any time.
