SOURCE: My turntable, cassette player line out does not
Connect the line OUT on your turntable to the line IN on your computer.
Some sound cards are more sensetive than others so you may require a PRE-AMP between the two items.
These are not too expensive or bulky and available at a large variety of places such as radio shack and many places that sell component audio devices such as recievers etc.
http://www.radioshack.com/product/index.jsp?productId=2541471
Hope this gives you the information you need
Bob
Moderator
It would be very decent of you to consider the quality of our expert’s answers and judge them accordingly as you pass through FixYa.
Thank you
SOURCE: Dell XPS 410 power supply
This issue happens when your computer is using or requiring a large amount of power source or the power supply is simply dying out already. You may want to update the BIOS. If the problem perists, replace power supply.
I hope this works for you. Good Luck!
Mongkey
"Understanding explains better..."
One bad or faulty lead connection can cause a computer to continue restarting on a cycle or to shutdown or fail to detect your hard drive
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
hope this helps
