Dell XPS 410 PC Desktop Logo
Posted on Sep 21, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dhcp client cant connect to a network
Anonymous
Level 3:
  • Dell Master 2,878 Answers
  • Posted on Sep 22, 2012
Anonymous
Dell Master
Level 3:
Answers
2878
Questions
0
Helped
488153
Points
8243
DHCP provides an IP address. This comes from your ISP or a wireless router if you have one. Always leave it on DHCP unless you were provided by a static IP.
Why Addresses in the IP Address Pool on a Switch Are Exhausted When the Switch Functions as a DHCP Server and It Has a Few Clients?
If the IP address pool has much more resources than needs of clients, the following two reasons may cause address exhaustion:
1. An attacker keeps changing the CHADDR field and sending DHCP Discover packets to exhaust addresses. If so, contact Huawei engineers to deploy DHCP snooping to protect the IP address pool.
2. The DHCP server ping function is enabled on the DHCP server. This function tries to ping the allocated addresses before responding to DHCP Offer packets. If a client responds to any ping packet, the DHCP server considers that there are address conflicts and addresses are exhausted. To solve this problem, two methods are available:
1. Capture packets on the ports connected to the DHCP server. If a client responds to ping packets, prohibit the client.
2. Disable the DHCP server ping function using the undo dhcp server ping packet command.
3. Such as S5700, S6700
tip
DHCP Server configuration in Linux
Linux is a UNIX based operating system. It is a server operating system. REDHAT Linux is Enterprise version of Linux. Now a day's Most of corporate sectors use red hat Linux as server in their company because it is secure very much.
Full form of DHCP "Dynamic Host Configuration Protocol. DHCP server assigns IP addresses and other network configuration information like subnet mask, broadcast address, etc to computers on a network. The DHCP assignments are the following.
Lease Request: Client broadcasts their request to DHCP server with a source address of 0.0.0.0 and a destination address of 255.255.255.255.
IP lease offer: DHCP server replies with an IP address, subnet mask, network gateway, name of the domain, name servers, duration of the lease and the IP address of the DHCP server.
Lease Selection: Client receives offer and broadcasts to al DHCP servers that will accept given offer so that other DHCP server need not make an offer.
The DHCP server then sends an ack to the client. The client is configured to use TCP/IP. Lease Renewal: When half of the lease time has expired, the client will issue a new request to the DHCP server.
Installation of DHCP server: First of all while install the RedHat Linux enterprise version server be careful about the ports and the services must be turned on. To create DHCP server in Linux first download DHCP RPM package and install with "rpm-ivh" command. Where I have done it there I have create YUM server, so easily I have download and install it by YUM (yum install dhcp version). DHCP package will locate in /usr/share/doc/at Linux file system. I copied the DHCP's files from /usr/share/doc/ to /etc/dhcpd.conf.. Then I started to configure the dhcpd.conf file to route the DHCP server in there local network. I have open the configuration file with "vi" command. Then commented out the lines from "default gateway to option netbios" because system don't read the commented lines. After that I set the range of IP address in dynamic- bootp of their local assumption of system. I have change the "next-server" with the dhcp server name and have also change the fixed address with the dhcp server IP address (end range of dynamic IP). It is very easy job to configure DHCP server. After configure the .conf file of dhcp just turn on the service with "chkconfig" command and restart the dhcp service. After that entire job I reboot the system. And after rebooting of server I turned on the other client system. While startup the client system without static IP address all of those picked up IP from dhcp server and going on successfully. I have prefer the command line mode to do the total job.
The DHCP server configure file is following:
ddns-update-style interim
ignore client-updates
subnet 192.168.1.0 netmask 255.255.255.0 {
# The range of IP addresses the server
# will issue to DHCP enabled PC clients
# booting up on the network
range 192.168.1.201 192.168.1.220;
# Set the amount of time in seconds that
# a client may keep the IP address
default-lease-time 86400;
max-lease-time 86400;
# Set the default gateway to be used by
# the PC clients
option routers 192.168.1.1;
# Don't forward DHCP requests from this
# NIC interface to any other NIC
# interfaces
option ip-forwarding off;
# Set the broadcast address and subnet mask
# to be used by the DHCP clients
option broadcast-address 192.168.1.255;
option subnet-mask 255.255.255.0;
# Set the NTP server to be used by the
# DHCP clients
option ntp-servers 192.168.1.100;
# Set the DNS server to be used by the
# DHCP clients
option domain-name-servers 192.168.1.100;
# If you specify a WINS server for your Windows clients,
# you need to include the following option in the dhcpd.conf file:
option netbios-name-servers 192.168.1.100;
# You can also assign specific IP addresses based on the clients'
# ethernet MAC address as follows (Host's name is "laser-printer":
host laser-printer {
hardware ethernet 08:00:2b:4c:59:23;
fixed-address 192.168.1.222;
# List an unused interface here
subnet 192.168.2.0 netmask 255.255.255.0 {
on Mar 17, 2011 • Computers & Internet
1helpful
2answers
Major wireless problems.. I can connect to my wireless router (Thomson 585v8) but i cant connect to the internet. When it connects it says local only. How do i fix it so i can go on the internet..??
check if the ip address that you are getting begins with 192.169.x.x ( x = any number between 1 to 254) check that your router the DHCP service is enable and that there a network range set (example lets say your gateway ip is 192.158.0.1 then your dhcp by defult in most cases will look like this ip range 192.168.0.2 - 192.168.0.254 using a netmask of 255.255.255.0 that will give you 254 ips per network.)
if your ip start with 192.169.x.x the that means that your machine is not getting a real ip assigned to it all you get is an APIPA that is just a reseved ip by the system to fill out ethernet interfaces that don't have and static ip or are in a network without a DHCP server.
you can set a static ip in the client pc if you don't want to enable DHCP in the router.
when you see Local Only message it means that your pc hasn't detected a route to the outside network ( internet ) without a proper gateway you will not be able to get to the internet, your router ip is always your gateway.
example:
Router Client pc
IP 192,168.0.1 IP 192.168.0.2
subnet mask 255.255.255.0 subnet mask 255.255.255.0
default gateway 192.168.0.1
How to turn on a dhcp on a rca model dcm425 cable modem?
Enabling DHCP at the Client To enable the Windows NT DHCP client, you must log on as administrator at the Windows NT client.
Normally, you enable DHCP as part of the installation procedure for Microsoft TCP/IP, however, you can use this procedure if you have manually configured TCP/IP:
  1. Run Control Panel and choose Network.
    The Network Settings dialog box appears.
  2. Under Installed Network Software, select TCP/IP Protocol and then choose configure.
    The TCP/IP configuration dialog box appears.
  3. Select Enable Automatic DHCP Configuration.
    A Microsoft (MS) TCP/IP message appears, indicating that the DHCP Protocol attempts to configure the server automatically during system initialization.
  4. Choose Yes.
    A MS TCP/IP Configuration dialog box appears, displaying current TCP/IP configuration parameters. The IP Address and Subnet Mask boxes are not available (grayed out) and the manually configured values are no longer displayed.
  5. Choose OK to return to the Network Settings dialog box.
  6. Choose OK again.
  7. Shut down and restart the computer.
To enable DHCP on a Windows for Workgroups client if TCP/IP is not installed yet:
  1. Use Network Setup to install the MS TCP/IP-32 3.11 protocol.
  2. In the MS TCP/IP Configuration dialog box, select the Enable Automatic DHCP Configuration check box, and choose Continue.
  3. Restart the computer to initialize TCP/IP using DHCP.
To enable DHCP on a Windows for Workgroups client if TCP/IP is installed:
  1. To access the Network Drivers dialog box, run Network Setup.
  2. Select Microsoft TCP/IP-32 3.11, and then choose Setup.
  3. In the MS TCP/IP Configuration dialog box, select the Enable Automatic DHCP Configuration check box, and choose continue.
    A message box appears indicating that the configuration of DHCP overrides any values established locally.
  4. Choose Yes.
  5. To initialize TCP/IP using DHCP information, restart the computer.
I am trying to connect my Dlink DKT-401 router to my Linksys cable gateway router. I am not getting internet access when connecting to the Dlink network
I DON'T THINK YOU CAN RUN 2 ROUTERS ON THE SAME NETWORK UNLESS ONE IS USED AS AN ACCESS POINT.
1. Connect as local device or bridge - If connecting the second router via Ethernet cable, plug it into one of the LAN ports on the first router. If connecting the second router wirelessly, ensure the second router is set for client mode. Note that some home wireless routers do not support client mode; these must be connected by cable. Check your router documentation for details on its client mode configuration support.
2. Check / change IP address - Most home network routers use a default IP address setting. Often, these default IP addresses will not work in a two router environment. Check the second router's IP address value and reset it if necessary to work within the valid address range of the first router (and to not conflict with any other device on the network).
3. Disable DHCP - To avoid IP address conflicts between all of the devices on the home network, only one of your two routers should assign addresses via DHCP. All mainstream routers provide an option to disable DHCP as part of the router's configuration screens.
Instead of adding a second wired router to an existing network, consider adding a network switch instead. A switch accomplishes the same goal of extending the size of a network, but it does not require any IP address or DHCP configuration, greatly simplifying configuration.
Readers Respond:
My PC is connected to this modem/router and works fine. All the laptops in the house show that they are connected but I can't get any websites on any of them. Also, when I connect the laptop with an...
Log in on your router manager http://192.168.x.x and enable DHCP.DHCP provides an automated way to distribute and update IP addresses and other configuration information on a network. A DHCP server provides this information to a DHCP client through the exchange of a series of messages, known as the DHCP conversation or the DHCP transaction. If the DHCP server and DHCP clients are located on different sub-nets, a DHCP relay agent is used to facilitate the conversation.
  1. Connect to your router (by typing 192.168.0.1 or 192.168.1.1 into the URL bar) and log in. Check your user manual or documentation if you do not know the log-in credientials.
  2. 180px-dhcp_router_setup.jpg magnify-clip.png Router Setup tab Make sure you are in the Setup -> Basic Setup category.
  3. 180px-dhcp_router_disabled.jpg magnify-clip.png DHCP is Disabled Scroll down until you see 'DHCP Server' - if it is disabled, select 'Enable'
  4. 180px-dhcp_router_enabled.jpg magnify-clip.png Enable DHCP If you want, you can change the number that the DHCP IP assigning starts. This is optional, and is totally dependant on personal preference.In this picture, the maximum number of DHCP clients is 3. You may need to increase this number according to how many people will need a dynamic IP address on your network. Once the max is reached, no one else can get an address until one expires!
  5. Use the DNS servers provided to you by your ISP, or use the following DNS servers: 205.152.37.254, 205.152.132.235, 205.152.132.23; There are many DNS servers out there. It's best to use your ISP's if possible.
  6. dhcp_router_save.jpg magnify-clip.png Don't forget to save! Scroll down and click 'Save Settings'
  7. Open up the network configurations for the computers on your network (Control Panel -> Network Connections -> Local Area Connection or Wireless Connection) and select 'Obtain IP address automatically'
5helpful
2answers
We have a DHCP problem with our thin client HP T5540, the network interface can't get an ip address fom the DHCP server for 30 seconds so it can't connect to citrix xen serverver for virtualization...
First of all check the configuration of the unit if it's AUTOMATIC IP/DHCP, if all OK you can test by configuring a static IP (use an unused IP in the server's DHCP table) than check the connectivity (ping something), if that works you have a server rule/DHCP or DNS problem
if it's still not working check the cabeling and connectors for connectivity (with a good cable tester) or an other (working) computer.
2answers
DHCP client services not running
Try to set a static ip address, this is a common problem in Windows Vista.
Ip conflict by using media of fiber cable in same network
You can configure the router to hand out DHCP clients in an assigned range. Set a limit on the DHCP clients, then configure the fiber connection as static and outside of the DHCP range. then they cannot conflict.
Cant connect
Roger Dodger.. Make sure that your security1.gif password is correct.
Then:
start>control panel>administrative tools>services
Make sure your DHCP client and wireless zero client are started and set to startup type automatic.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
