Whenever i start driving from a start the noise doesn't start until i hit high rpm or a hard bump in the road. p.s. when the noise starts it still runs and drives fine, but if i come to a complete stop turn the truck off and then restart it the noise stops until i hit high rpm or a hard bump again is there neone out there that can help me figure out what this could be?
SOURCE: 2000 chevy silverado 1500 4.3 eng
Chevy Trucks, Blazers, S10 pickup and the like will vapor lock ecspecially the 2000 models. Do not tighten the gas cap past 1 click. There is a tube that runs from the top of the tank down and this gets hot and collapses or burns in half. We just bought a reinforced rubber tube cut it to lengh and use it instead of part and it's worked grat for 2 years so far.
SOURCE: 2000 CHEVY SILVERADO 5.3L FUEL GAUGE PROB.
The problem is in the tank.The sending unit float gauge is worn.Its a factory GM issue.You will Need to replace the sending unit in the tank.I had the same problem and thats what I found.Its real common and this will solve your problem..Its 67.00 Dollars on Ebay..
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
SOURCE: 2001 Chevy 2500HD 6.0L, Hard starting.
Check the fuel pressure, bad fuel pump or sock on the fuel pump and fuel filter check spark plugs and check distributor cap, a fuel pump is $273.00 or a bad injector $110.99 or BWD Fuel Vapor Pressure Sensor for $35.99 any of these parts could cause the problem, so without doing a fuel pressure test it is a guess, if the vapor switch is bad it could cause a long crank time if the fuel pump is bad it has a check valve in the fuel pump, if the check valve goes bad the pump can't maintain fuel pressure so on start up the fuel has to pump from the tank all the way up to the fuel rail, if the injectors is bad it could leak after engine shut down and cause you to lose fuel rail pressure. Also the fuel vapor sensor could be stuck open and could cause the problem, all need to be tested, you can rent the fuel pressure tester from AutoZone or advance auto or Shucks they return your money when you bring the tool back as long as you buy the parts to repair it from them. That would be the first thing I would check fuel pump pressure and if you replace the pump then change the fuel sock as well. That model was not meant to burn ethanol and can kill the fuel sock the fuel pump and filter.
try with change the spark plugs
http://schematicsdiagram.blogspot.com/2011/12/how-to-adjust-rpm-on-2009-dodge-charger.html
Engine cuts out at 3000 RPM?http://schematicsdiagram.blogspot.com/2011/12/engine-cuts-out-at-3000-rpm.html
Cold start problem and vehicle shudder around 2500 to 3500 rpms
http://repairhelpcenter.blogspot.com/2012/10/cold-start-problem-and-vehicle-shudder.html
High rpm in neutral? Inconsistant high RPM in neutral?http://technoanswers.blogspot.in/2012/02/high-rpm-in-neutral-inconsistant-high.html
Jetski Sputters and Low RPM? http://whatisbyme.blogspot.in/2012/07/jetski-sputters-and-low-rpm.html
Fuel Injection Problem And RPM suddenly increaseshttp://whatisbyme.blogspot.in/2012/07/fuel-injection-problem-and-rpm-suddenly.html
2005 Toyota Highlander: Engine runs hard RPM below 3000?http://whatisbyme.blogspot.in/2012/05/2005-toyota-highlander-engine-runs-hard.html
1987 Toyota Camry: RPM Drops going Up hills?http://whatisbyme.blogspot.in/2012/05/1987-toyota-camry-rpm-drops-going-up.html
Cruise Control stops working, Excessive cranks to start the engine and RPM goes max 2500 http://whoisbyme.blogspot.in/2012/07/cruise-control-stops-workingexcessive.html
1990 Toyota 4Runner: Engine cuts off when reaches 2000 RPM?
http://whatisbyme.blogspot.in/2012/05/1990-toyota-4runner-engine-cuts-off.html
1999 Toyota Camry: Erratic stalling and high engine RPM at idle?
http://whatisbyme.blogspot.in/2012/05/1999-toyota-camry-erratic-stalling-and.html
1995 Toyota LS: Misfire at idle or low RPMhttp://whatisbyme.blogspot.in/2012/04/1995-toyota-ls-misfire-at-idle-or-low.html
Lexus RX: Tapping noise under Valve Cover At Low RPM?http://technoanswers.blogspot.in/2012/04/lexus-rx-tapping-noise-under-valve.html
These will help.
Thanks.
