The video format from your medium doesn't support the tv's max resolution
This might not be the tv's fault. Have you tried checking the HD PVR outputs in full HD. If it does see if there is a display setting that allows you to set the resolution to 1080p. Once you're sure the signal is 1080p then start looking through the TV's settings (or maybe simpler would be to check the manuals - you can usually find them online quite easily).
