SOURCE: Buzzing noise from Mitsubishi DLP WD-52327 after replacing bulb
Did your replace lamp come on the screen or did you lose picture? Just because the LED indicator suggest replace lamp it doesn't mean it needs it. If your pix was dull or loss of brightness then replace it, if not then just reset your lamp timer, check your owners manual for instructions.
SOURCE: status lamp lights-up on front no picture
The lamp is not that exspensive you should be able to get one for around $150 and you can replace it yourself.
The lamp can be bought as a lamp or you can order the entire cartridge, I would suggest the cartridge, unless you are handy at taking things apart as the cartridge can be tricky to take apart without breaking it. The only difference will be the cost. It is your choice. The Mitsubishi part number is 915P020010
You can google this and find many places to purchase the lamp or cartridge on line.
Replacing the Lamp Cartridge Tool needed: Phillips screwdriver
1. Turn the television off and unplug the AC cord.
2. Remove the front speaker grill by gently pulling on each side. The grill will snap out.
3. Using a Phillips screwdriver, remove the three screws (one on the left and two on the right side) that hold the recessed plastic cover in place.
4. Remove the plastic cover and set aside with the screws.
5. After removing the cover, you will be able to see the lamp cartridge. With the screwdriver, loosen the threes crews of the cartridge. The three screws will not completely remove.
6. Gently grasp the metal handle and pull straight out (towardsyou).
7. Insert the new lamp cartridge securely into the TV. Do not touch the glass surface of the cartridge.
8. With the screwdriver, tighten the screws on the lamp cartridge.
9. Replace the plastic cover and screws.
10. Snap the speaker grill back into place by pushing it into place on each side with the palm of your hand.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Testimonial: "thank you very much you told me me exactly what i needed to know your the man thanks again louis"
SOURCE: WD-52327 The TV turns on, lamp
Have you replaced the Lamp and Made sure Lamp Fan is running? Mats has Lamps for $99.00 1-800-628-1118
SOURCE: My Mitsubishi WD-62525 wont even turn on. No
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired ofcourse) and found four bulged capacitors. Many electronics companies were sold capacitors that failed in 2-5 yearsinstead of 10-20. The capacitors failprematurely due to a lack of preservatives. Unfortunately, they were installed in allsorts of devices.
Here are some options for you.
1. Have it fixed by a professional
2. Open your TV and find PSB. Checkfor faulty caps. If you find some (bulgedor leaking) bad caps replace the entire board.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourselfit will save you hundreds.
I have a tip/tutorialon this site that may also help. Itgives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. It'scalled: Fixing the Philips Turns/shuts off on its own problem.
Hope this helps and Good luck.Kaufman605
