20 Most Recent
Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television Questions & Answers
Factory setting. Do a reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Mitsubishi...
Answered
on Jun 19, 2017
buy a flatscreen and consider it a down payment on 2 years worth of bulbs
Mitsubishi...
Answered
on Jul 29, 2015
unplug it from the wall, wait 30 seconds, then plug it back in. i had the same problem and this simple solution worked for me. Good Luck!!!!
Mitsubishi...
Answered
on Feb 13, 2014
Check the lamp its most likely shattered.
Mitsubishi...
Answered
on Jan 25, 2014
Have a look at the lamp first and the noise should be a fan.
Mitsubishi...
Answered
on Sep 03, 2012
follow the power into the set and to the power supply, a lot of these had puffed up caps on the power board kill the whole set-----You will not find it a real easy set to get into or open up
Mitsubishi...
Answered
on Aug 28, 2012
Connect RCA wires (yellow, red, white) from the box's "out" to the tv's Input 1 or 2 on the back input panel of the tv set. If you don't have RCA's you may use a RGA- jumper wire (cable wire made into a 4 ft segment by the tech or buy a short cable wire from the Walmart, Target, or Goodwill store) Connect this wire to the "cable in" on the tv and the other end to the "cable out" on the box.ADDITIONALLY make sure you have the right input settings selected on the tv with the input selection you make with the wire connection you choose.
Mitsubishi...
Answered
on Jun 21, 2012
The set should have lights on the front that blink when it does this--Lamp is possiblelamp Ballast is possible The set also has a error buffer that can be called up if shuts off--blink code on front of set.Another common issue is set will play for a while and shut off--which best describes your problem?
Mitsubishi...
Answered
on May 27, 2012
when you tune in a tv station or playing a dvd player. if you playing a dvd player maybe your vido cable is not fully insert the plug (yellow color) . The red and black/white are for the audio.
Mitsubishi...
Answered
on Apr 18, 2012
describing a optical light engine with growing defects---pixels in the display unit going bad
Mitsubishi...
Answered
on Apr 17, 2012
