Powershot SD 300
Set the Postcard Date Imprint. See page 74 of the manual: http://gdlp01.c-wss.com/gds/0/0900001380/01/PSSD300200CUG-EN.pdf
However, this mode reduces the resolution so that you won't be able to make prints much larger than postcard size. If you want to set a higher resolution so you can make larger prints, then the camera won't deface your photos by scrawling a string of numbers across them.
All is not lost, though. The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
SOURCE: how do you set am/pm after you set the time on a canon A710is
after setting rhe time please seeup/down arrow mark icons,press the down mark icon to get PM.
SOURCE: canon a 400 powershot turns off when try to format sd card
Have you tried to format it from the computer? if not, try on 16bit. If that still doesnt work scan it with FixFakeFlash Since lately its a very common problem having a fake Mem that fails it the worst moment
