Volumn is loud, stay at same level all the time, won't adjust up or down
Reset the code for r. control download from www. remotecodelist.com
2) clean the contacts battery
3) retight the spring contacts battery with pliers for better contacts.
4) otherwise you must go to the repair shop TV for fix it.
God bless you
Thank you.
o.k give me some news. God bless you
Your solution did not solve my problem. Everything on my remote works fine. The tv responds except the volumn does not respond to the remote or by using the volume buttons on the tv. So thanks for responding, but I still have a volumn problem. I did however clean my remote with your instructions and it works better.
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
